Fuel injected CJ and smogging in California - JeepForum.com
post #1 of 8 Old 08-13-2012, 10:24 AM Thread Starter
topless_cj
1983 CJ7
Hi all,
83 CJ7 with a Mopar MPI kit on my 258. Always had issues with visual part of smogging in California, but always managed to find a mechanic that was familiar with the situation.
Has been in PA for a while and want to bring the Jeep back to southern CA.
Does anyone have any suggestions for smogging mechanics that are familiar with old fuel injected jeeps or experience with these kits for getting the Jeep smog legal again? I am in the Norwalk area but will happily drive where a mechanic is familiar with my modification!
Just a basic kit from 4wd-hardware, no other modifications.
Super appreciative!
topless_cj is offline
post #2 of 8 Old 08-13-2012, 12:57 PM
FamousJerry
2014 JK Wrangler
do you have the C.A.R.B sticker for it? if not good luck. Tough to find someone that has any idea what they are doing smog wise on a jeep out here.
FamousJerry is offline
post #3 of 8 Old 08-13-2012, 03:00 PM Thread Starter
topless_cj
1983 CJ7
yes I do, and I agree with you, which is why I am posting and hoping others have found mechanics that have done this before.
post #4 of 8 Old 08-14-2012, 06:54 AM
gmakra
Unfortunately you don't have a choice when it comes to getting SMOG tested. You might get sent to a Test Only facility. As long as you have the C.A.R.B. sticker and everything is in working order and your emissions are below the threshold you should be good to go. If there is a dispute you can set up an appointment with a SMOG Referee.
gmakra is offline
post #5 of 8 Old 08-14-2012, 07:28 AM
mtndrew
1983 CJ7
I have an identical setup as yours 83 258 multiport fuel injection and in so cal. Take it to a referee and keep your paper work from there on out and every smog shop will be a lot less likely to hassle u. Before I went through a referee I had guys saying I wouldn't pass visual as soon as I showed them the paperwork they just shut up and said no prob
mtndrew is offline
post #6 of 8 Old 08-14-2012, 08:54 AM
PERK
if you have both stickers that came with the kit your good. the smog guy is going to test your fuel system for leaks by pressurizing the tank, if you have not replaced your vent and fill hoses in a long time they will leak. you should get a new nonvented gas cap..it will be tested.
PERK is offline
post #7 of 8 Old 08-15-2012, 12:46 AM
Blue83CJ7
1980 CJ7
Google the CARB EO number on your sticker, print it and bring it with you. Is this the right one for your kit: http://arb.ca.gov/msprog/aftermkt/de...o/D-265-7.pdf?
Make sure you have removed all the things the letter tells you to remove, and that you added all the sensors they say come with the kit, vacuum lines per the new sticker, etc.
Also, check your gas tank vents/purge system, rollover valve etc are all hooked up and the lines aren't cracked, clamps are tight, etc. He will clamp the vent line at the charcoal canister under the hood and pump like 5psi into your tank and it has too hold a % of it for a few minutes.
You may want to bring an extra gas cap in case your gas cap fails, had that happen on my last jeep.
I have the Howell kit and they gave me a hard time until I gave them that printout that matched the EO on my sticker. I had to explain why the unused port on the TBI was plugged with a vacuum line and bolt, then trace the vacuum wires for him that matched my howell sticker but he was cool after that.
The only thing they dinged me for was that for the first test I had a "snail" type air cleaner assembly that routes over the valve cover and ends with a cone type element and the letter called for an "open" air filter, but I made them run it through anyway so I would know if it would pass otherwise, since I knew I had a free retest. Came back and nailed it.
Finally, shop around for price matching and free retest or don't pass=don't pay deals.
One shop wanted over $120 bucks with no free retest but I drove 10 minutes away and did it for $54 with a free retest "if I come in right now"
Good luck!
1980 CJ7 - The Grenade
Blue83CJ7 is offline
post #8 of 8 Old 08-15-2012, 07:55 PM
Blue83CJ7
1980 CJ7
Here's the one for the CA legal Howell CA legal kit for the 72-91 4.2l
http://db.tt/ObnIGKSa
california , cj , fuel injection , smog
Fuel Injected CJ7 Rough85CJ7 Jeep CJ Forum 3 01-11-2010 02:02 PM
new question. 89 302 fuel injected. Taking2long Jeep CJ Forum 11 10-04-2009 05:46 AM
Fuel Injected AMC 360 mjp83 Jeep CJ Forum 7 07-03-2009 07:16 PM
California Cjs i have a question about smogging and buying wider leafs Goobersbro Jeep CJ Forum 16 01-09-2009 04:30 PM
225 fuel injected? 0IIIIII0 Jeep CJ Forum 0 07-15-2004 03:48 PM
