Fuel hose length - JeepForum.com
post #1 of 9 Old 07-18-2013, 09:21 AM Thread Starter
wwhitby
1979 CJ5
Fuel hose length
My long-delayed reinstall of my fuel tank is almost done. The tank is ready to go back in. I want to install and clamp down the lines from the fuel sending unit and the two lines that go to the check valve before I put the tank back in.
However, I haven't been able to find out how long any of those lines need to be. I want to cut them to the correct length before I install the tank so that I don't have to mess with cutting them when the tank is in.
Does anyone know what the length of those lines needs to be?
Thanks,
Warren
Warren Whitby
1979 CJ-5 "Big Blue"
Real Jeeps have rust
Just Empty Every Pocket
wwhitby is offline
post #2 of 9 Old 07-18-2013, 10:09 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You still have all the stock parts? Wow..
Anyways 15 and 20 gallon tanks are different. Which one do you have.
Note: I don't have an answer for you but might help one who knows if you know what tank you have.
Mine were attached with the body off.
John Strenk is online now
post #3 of 9 Old 07-18-2013, 12:54 PM Thread Starter
wwhitby
1979 CJ5
I've still got some of the stock parts on there. Mostly the ones that haven't broke or haven't been replaced
Its a stock 15 gallon tank. The metal fuel lines and check valve are also stock.
Warren Whitby
wwhitby is offline
post #4 of 9 Old 07-18-2013, 01:13 PM
82JeepCJ7
1982 CJ7
If you still have the old lines, use them as a template.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 9 Old 07-18-2013, 01:16 PM Thread Starter
wwhitby
1979 CJ5
Unfortunately, I don't have them. I don't know how much help it would have been, since some of the lines had been "dissolved" by ethanol.
Warren Whitby
wwhitby is offline
post #6 of 9 Old 07-18-2013, 02:03 PM
82JeepCJ7
1982 CJ7
When I put my tank back in, I ran an excess of fuel line off the connections, then trimmed them up as I connected the lines. Pretty easy to do.
post #7 of 9 Old 07-19-2013, 05:37 AM
John Strenk
1976 CJ5
A bump for you since you didn't get an answer yet...
I would go with the "Longer than needed" and cut to fit approach...
post #8 of 9 Old 07-20-2013, 06:26 AM Thread Starter
wwhitby
1979 CJ5
Thanks John!
I put the tank back in yesterday and used the "cut the hose after the tank is installed" method.
I cut the hoses with a utility knife, and if I had to do it over again, i'd use one of the special tools that look like sheers with a knife blade in the jaw. It would be much easier than sawing back and forth.
Warren Whitby
wwhitby is offline
post #9 of 9 Old 07-20-2013, 08:23 AM
82JeepCJ7
1982 CJ7
I use a pair of wire cutters on mine. Snip... done. A nice clean cut. If you need to reach up in somewhere, they are nice for that as well.
