Fuel Gauge Sender Unit Help - JeepForum.com
post #1 of 8 Old 10-03-2011, 10:51 AM Thread Starter
al2ride
1976 CJ7
When I bought my CJ, the previous owner told me to watch the fuel gauge because it didn't work properly. Come to find out, someone had drilled through the gauge housing and had glued the needle at about 3/4 full. So I ordered a brand new exact replacement from what it was installed (see photo), but when hooked up the needle pegs beyond empty/full...can't remember which extreme. I'm guessing that the gauge's resistance range is not matching the sending unit. I also noticed that the fuel tank is a huge metal tank...I'm guessing 20 plus gallons or so. Do I need to go with the stock speedo/fuel/temp gauge to make the fuel gauge work properly or is there anything else I could do to keep the really nice white faced gauges. They are the Phantom Auto Meter gauges.
al2ride is offline
post #2 of 8 Old 10-03-2011, 11:15 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You should be able to make the gauge work but you will probably have to take the sending unit out.
You need to match the resistance ranges on the gauge match the one in the tank. Didn't the gauge come with any information?
Possibly a bad sending unit also
John Strenk is offline
post #3 of 8 Old 10-03-2011, 11:49 AM
SleeperCJ
1983 CJ7
I have those same gauges, runny a stock sending unit and for the longest time I couldn't figure out why my gas gauge didn't work. Turned out I had the wrong gauge for the stock sending unit. You can use an autometer gauge with the stock sending unit, I think the right gauge part no. Ends -15 and I had -17. The ohm range you want is like 0-73 ohms.
SleeperCJ is offline
post #4 of 8 Old 10-03-2011, 02:57 PM Thread Starter
al2ride
1976 CJ7
Yeah, I just looked at the specs for the one I have Model Number 5718, and the range is 16 ohm empty and 158 ohms full. I think that's pretty much backwards from what the stock unit is and why is pegging out. Did you end up getting the right one?
al2ride is offline
post #5 of 8 Old 10-03-2011, 03:12 PM Thread Starter
al2ride
1976 CJ7
You are right on ending -15. It's actually Model Number 5715 which is 73 ohm empty and 10 full, which is what the stock sender unit is.
al2ride is offline
post #6 of 8 Old 10-03-2011, 03:14 PM
SleeperCJ
1983 CJ7
Yeah thats the one. I haven't had my engine running since I put the new one it, but when I turn the keys I get a reasonable fuel level reading. I have the 20 gallon tank also, it is plastic with a metal shroud/skid plate.
post #7 of 8 Old 10-04-2011, 09:58 AM Thread Starter
al2ride
1976 CJ7
I have a huge, don't know how many gallons, metal tank. When I went to redo my fuel lines (pump to carb) I noticed contaminated brownish fuel. It looks like it's time to replace the tank. I'm going to go with a plastic tank alone with a new sender unit and hopefully that solves my problems.
al2ride is offline
post #8 of 8 Old 10-04-2011, 10:45 AM
SleeperCJ
1983 CJ7
Right on. I started up my engine last night and the new fuel gauge appears to be working. The 5715.
checking for intrest; Sender and filler hose, Fuel sending unit SD84CJ7 Jeep CJ Forum 0 07-08-2009 01:24 PM
is the 82-86 20 gal sender compatable with my 80 fuel gauge? COBRA5LADDICT Jeep CJ Forum 4 07-07-2009 03:49 PM
ANOTHER fuel sender unit question! JUNK726 Jeep CJ Forum 1 02-14-2009 01:20 PM
INstalling Fuel sender unit in new tank ishcak Jeep CJ Forum 5 07-09-2006 03:04 PM
Fuel Tank Sender Unit ppd1108 Jeep CJ Forum 3 04-24-2003 10:30 AM
