Fuel Gauge Reads Backward..maybe? - JeepForum.com
post #1 of 4 Old 02-02-2013, 04:29 PM Thread Starter
davbytrace
1979 CJ7
1979 CJ7 with 304.
I installed a VDO fuel Gauge in the dash. I verified that the gauge is appropriate for the ohm range that the CJ sender operates at. When I installed it, the tank was 1/2 full, and the gauge read 1/2 as it should.
When I filled it up, the gauge went to zero.
Has anybody seen this happen? Any clues?
davbytrace is offline
post #2 of 4 Old 02-02-2013, 05:46 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Might be the right resistance range but backwards.
John Strenk is offline
post #3 of 4 Old 02-02-2013, 10:09 PM Thread Starter
davbytrace
1979 CJ7
Soooo....could I hook the signal to the negative and ground to the signal and get a correct reading?
post #4 of 4 Old 02-03-2013, 05:32 AM
John Strenk
1976 CJ5
Chances are no.
Most likely reversing the voltage will drive the meter into the opposite direction.
You could install a YJ sender. They have the opposite resistance range.
