-   -   Fuel Gauge Reads Backward..maybe? (http://www.jeepforum.com/forum/f8/fuel-gauge-reads-backward-maybe-1472896/)
davbytrace 02-02-2013 03:29 PM
1979 CJ7 with 304.
I installed a VDO fuel Gauge in the dash. I verified that the gauge is appropriate for the ohm range that the CJ sender operates at. When I installed it, the tank was 1/2 full, and the gauge read 1/2 as it should.
When I filled it up, the gauge went to zero.
Has anybody seen this happen? Any clues?
John Strenk 02-02-2013 04:46 PM
603 Attachment(s)
Might be the right resistance range but backwards.
davbytrace 02-02-2013 09:09 PM
Soooo....could I hook the signal to the negative and ground to the signal and get a correct reading?
John Strenk 02-03-2013 04:32 AM
603 Attachment(s)
Chances are no.
Most likely reversing the voltage will drive the meter into the opposite direction.
You could install a YJ sender. They have the opposite resistance range.
The time now is 07:04 AM.
