Fuel Gauge not working - JeepForum.com
post #1 of 12 Old 01-23-2002, 12:13 AM Thread Starter
CJ7Eric
Post Fuel Gauge not working
My fuel gauge on my 83 CJ7 doesn't work. I have checked the ground and it seems like it has a good connection. The temp. gauge next to it is also not working. Any ideas on how to test the gauge itself to see if it still works from under the dash? I have a Resistance gauge to tell if the circuit is working to the back but I am having problems figuring that out today.
CJ7Eric is offline
post #2 of 12 Old 01-23-2002, 02:04 PM
Jeep Daddy
Jeep Daddy's Avatar
Post
When you find out the answer, please let me know too. I've got an 85 CJ with a 20 gal tank and 258ci engine. Gas and temp gauge not working. Email me at realbud@att.net if you get some answers. Thanks
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #3 of 12 Old 01-23-2002, 02:52 PM
Jami
1973 CJ6
Post
I am not 100% on all of this but I will tell you what I know. If both of these gauges are not working there is probably a power problem. The temp gauge receives it's power from the fuel guage so if they are both not working check the power(I post)at the fuel guage. If you do have power I would guess that it is either the guages or the senders(unlikely for both to be bad. Good Luck and I hope it helps.
73 CJ-6 in the works
Jami is offline
post #4 of 12 Old 01-23-2002, 03:37 PM Thread Starter
CJ7Eric
Post
I let you know what I figure out.
CJ7Eric is offline
post #5 of 12 Old 01-23-2002, 09:05 PM
MeandmyCJ
Post
Check out http://www.monsterslayer.com/jeep/Gauges.htm for one of the better articles on troubleshooting CJ gauge problems.
'83 CJ5 w AMC304
Last year of the CJ5
MeandmyCJ is offline
post #6 of 12 Old 01-23-2002, 11:11 PM Thread Starter
CJ7Eric
Post
That site is great! Thanks meandmycj7!
CJ7Eric is offline
post #7 of 12 Old 02-18-2002, 10:24 PM
mxg342
mxg342's Avatar
Post
I had the same problem on my 84 CJ-7. However I opted to change out the gauges. I cut new holes in the dash and put regular gauges in. When I did this everything worked. I also tried switching speedo assemblies before this just to find that the gauges were bad in it too.
Also I was reading up in 4 wheel drive's catalog and they recommend changing both the fuel and temp gauges as a pair. This of couse in your case will be nessecary. these gauges aren't very expensive adn can be picked up from 4 Wheel Drive Hardware. Hope this helps.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #8 of 12 Old 02-19-2002, 02:07 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
Find the wire going to the sending unit off the back of the gauge. ground a test light and touch the end to the stud. The light should blink and the gauge should go up. If the light doesnt blink then check the power wire going into the gauge.If it doean't light then there isnt any power going to the cluster.If it does light on the power side but doesn't blink on the sender side then the voltage regulator is bad.if it blinks and the gauge goes up then the problem is in the wiring from the gauge to the sending unit or the sending unit itself.
bazinga
jeepdaddy2000 is offline
post #9 of 12 Old 02-19-2002, 12:27 PM
coopcj7
Post
Hey I had that same problem on my CJ7 it turned out that my fuse was blown and when i replaced it all was fine.
coop
Brian Cooper
1977 CJ7
Glass body
304 bored over .030
Chevy 350 coming soon (i hope)
2in lift
31" Cooper HT's
custom 2 wheel drive (temporary)
coopcj7 is offline
post #10 of 12 Old 02-19-2002, 10:23 PM Thread Starter
CJ7Eric
Post
I'm still messing wtih the gauge. I can't find the fuse for the gauges but I assumed if I was getting current from the red wire then the fuse was ok. I measured it and it read about 12 Volts. I'm thinking the gauges have gone bad. Seems weird that both have gone bad.
CJ7Eric is offline
post #11 of 12 Old 02-19-2002, 11:42 PM
jeepdaddy2000
1971 CJ5
Post
I'm working from memory here but if I recolect right there should be a power wire to the fuel gauge input stud. there should be a wire from a 2nd stud to the sending unit.There should be a stud in the middle with a flat strap connecting it to the temp. gauge. A wire goes from the temp gauge to the sending unit. If you have power to the fuel gauge but no power out then the voltage regulator is bad and you will have to replace the fuel gauge. If you have power on the sending unit side(blinking test light) then the problem is between the gauge and (including) the sending unit.
bazinga
post #12 of 12 Old 02-20-2002, 04:00 PM Thread Starter
CJ7Eric
Post
Thanks JeepDaddy, I'll give that a try.
CJ7Eric is offline
I Got My Fuel Gauge Working by Putting Stock Oil Gauge Back In Pog Jeep CJ Forum 4 11-09-2011 01:01 PM
75 cj5 fuel gauge not working john75cj5 Jeep CJ Forum 3 12-21-2008 10:58 PM
Fuel gauge not working fastas69 Jeep CJ Forum 3 12-16-2008 03:06 PM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 01:41 PM
temp and fuel gauge not working? aufderheide Jeep CJ Forum 7 02-22-2004 12:03 PM
