fuel flow problem - JeepForum.com
post #1 of 6 Old 08-19-2002, 06:51 AM Thread Starter
cjryder
fuel flow problem
I just replaced my leaky cj5 gas tank with another which is used.
The old sending unit was all bondo'd over so I used the one the the new tank. I somehow lost gas flow now.
The pump is working, I have flow from there to the carb, but not from tank to pump. Questions: Could it be the filter on the sending unit pickup? Also, there are 2 hose fittings on the sending unit, one is the fuel line to pump, what is the other?
(all my emissions stuff is long gone) can I cap it off?
There are 2 more fittings at the top rear corner of the tank also. I assume these are for emissions as well. Should they be vented or capped?
cjryder is offline
post #2 of 6 Old 08-20-2002, 07:09 PM
hollywood
On the sending unit, one line is the feed to the pump, and the other is for the return line. Some CJs use a fuel filter with an extra outlet (which must be installed with extra outlet pointing up) - This was to prevent fuel vapor build-up in the fuel lines. The other two connections on the tank were for evaporative emissions control. I just have mine plugged. As for your fuel delivery problem, you'll have to pull the sending unit from the tank to make sure you're hooked to the feed. Good luck
- Jeff
'83 cj
Another 7 by "CJ's Heaven"
hollywood is offline
post #3 of 6 Old 08-20-2002, 08:55 PM Thread Starter
cjryder
Thanks, Hollywood. Good input about the return feed. I already ordered another sending unit so I'll just drop the tank once when it arrives.
cjryder is offline
post #4 of 6 Old 09-11-2002, 09:50 PM
xjwannabe
hey cjryder
whats up gary i got a name xjwannabe got the name from you well i have found some pretty cool jeeps. i have been asking around in here. i have got some really good info thanks for the site see you this weekend
xjwannabe is offline
post #5 of 6 Old 09-12-2002, 07:24 AM Thread Starter
cjryder
Hi back at ya, xjwannabe. Welcome aboard.
You'll love this forum, these folks are friendly.
good luck with the xj, don't rule out cj's though.
cjryder is offline
post #6 of 6 Old 09-12-2002, 08:05 PM
xjwannabe
you know i woint
i could never do that they are all the best gotta love em all
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Fuel max and hi flow intake. Worth it?? Lockmin Jeep CJ Forum 1 09-27-2009 05:55 PM
Fuel problem? tmoreau Jeep CJ Forum 9 04-21-2007 02:35 PM
fuel flow diagnostics derm Jeep CJ Forum 2 09-17-2002 06:11 AM
1980 cj5 fuel flow problem? kasper37 Jeep CJ Forum 11 08-30-2002 10:33 PM
