Fuel Filter Replacement - JeepForum.com
post #1 of 4 Old 08-14-2009, 11:06 PM Thread Starter
havasu7
1979 CJ7
I have a 1979 CJ 7 that had a stock 304 in it and I put in a 401. I took all of the smog off of it. The original fuel filter had a return line on it back to the fuel tank. Does anyone know why or what it was used for. I capped it off and put a regular filter on it. The engine has seemed like it is starving for gas after i run it hard even though I put an electric Fuel pump on in it. It could have something to do with a gas tank venting issue. Has anyone had similar problems or no a cure? Thanks.
havasu7 is offline
post #2 of 4 Old 08-14-2009, 11:34 PM
sevenlitre2002
1983 CJ7
Same set up here, with a 360. No pollution stuff, regular fuel filter, no return line.
Mine runs like a top. The only difference I can think of is I didn't cap the return line.
I just cut it off where the charcoal cannister used to be, and left it open.
sevenlitre2002 is offline
post #3 of 4 Old 08-15-2009, 05:07 AM
Mike Romain
The gas tank will vacuum lock with no vent and starve the engine for fuel.
The vent is the charcoal canister. That is a good thing to have working because it also ties with the PCV line. The PCV controls engine sludge and won't operate right without the added air flow from the canister.
The return line is there to prevent vapor lock on a hot shutdown.
Mike
Mike Romain is offline
post #4 of 4 Old 08-15-2009, 08:29 AM
desmolift
1981 CJ7
Just the other day I went through this vapor lock issue with the fuel filter. If you are using the dual output filter w/return line, be sure it is installed correctly. It must be horizontal with the return line on the top. Otherwise, it will not return the vapors to the tank. Mine was installed incorrectly, and the return line was kinked. Although, I don't think I have a charcoal canister in the return path.
desmolift is offline
fuel filter help Brg0012 Jeep CJ Forum 9 11-10-2009 06:02 AM
Fuel filter/vapor-lock/fuel starvation...help please. hh65flyer Jeep CJ Forum 1 07-22-2009 03:05 PM
Fuel Filter robertmspeakout Jeep CJ Forum 2 04-08-2008 03:12 PM
replacement air filter drunkenrich Jeep CJ Forum 2 02-26-2008 04:22 PM
Fuel Filter MudLover Jeep CJ Forum 7 07-10-2003 08:08 PM
