fuel filter on cj5 - JeepForum.com
post #1 of 2 Old 07-24-2013, 12:57 PM Thread Starter
Stegs
fuel filter on cj5
is the fuel filter in the tank or outside on a 78?
any tips or pointers for me if I change it?
what brand filter works best?
Stegs is offline
post #2 of 2 Old 07-24-2013, 05:25 PM
james04si
james04si's Avatar
1977 CJ5
There is a sock in the tank but the normal fuel filter is under the hood between the fuel pump and carb. If it is stock it will have 1 inlet and 2 nipples on the other side. The center one goes to the carb, the one offset goes to the return line and should be oriented to the top of the filter. If it is on the side or bottom the line will lose its prime and cause it to take longer to start.
james04si is offline
