Fuel Filter??? - JeepForum.com
post #1 of 5 Old 02-18-2010, 08:05 PM Thread Starter
TheGhost
1983 CJ7
Fuel Filter???
I have recently installed a Weber 32 / 36 Carb on my 4.2 and am in the process of re-plumbing the fuel lines. The question is, do I need to keep the fuel filter with the return, or can this be replaced with a single outlet filter and the return eliminated?
TheGhost is offline
post #2 of 5 Old 02-19-2010, 07:29 AM Thread Starter
TheGhost
1983 CJ7
Bump......
TheGhost is offline
post #3 of 5 Old 02-19-2010, 09:30 AM
80jeepcj
1980 CJ7
i'm definitely not the expert here...but i have the same set up and i have the return. i'm pretty sure the return is necessary especially with the stock fuel pump and most people that know more than me recommend a pressure regulator as well. that would be the two cents that i've borrowed from others over the years =)
80jeepcj is offline
post #4 of 5 Old 02-19-2010, 01:23 PM
Mike Romain
The return is needed. It prevents vapor lock by being at the top of the filter so on a hot shutdown the vapors blow back tot he tank rather than vapor locking the gas line. It also has a metered hole so the main center line keeps the pressure right for a BBD carb.
A gent also flipped his filter around and used the smaller return line with it's metered hole in it as a fuel pressure regulator. It gave 1.5 psi at idle and 3 at speed I think:
http://www.jeepforum.com/forum/f8/fu...ml#post8435916
Mike
Mike Romain is offline
post #5 of 5 Old 02-19-2010, 03:19 PM Thread Starter
TheGhost
1983 CJ7
Thanks for the info. I sort of figured I'd need it. It's just sort of ugly and I was hoping to hard-pipe most of it.
TheGhost is offline
fuel filter help Brg0012 Jeep CJ Forum 9 11-10-2009 06:02 AM
Fuel filter/vapor-lock/fuel starvation...help please. hh65flyer Jeep CJ Forum 1 07-22-2009 03:05 PM
Fuel in Air Filter Jordy Jeep CJ Forum 5 07-19-2006 08:37 AM
Fuel Filter bfox48 Jeep CJ Forum 1 06-21-2006 11:18 AM
fuel filter bodi Jeep CJ Forum 3 01-18-2003 12:51 PM
