Fuel Economy - JeepForum.com
post #1 of 10 Old 07-03-2005, 11:39 PM Thread Starter
nsamaster0414
Fuel Economy
Hey, I was just wondering if there is anyway to improve my fuel economy short of putting in a different tranny/T-case combo. I am running a 79 258 I6, with Weber 32/36, on a T150. Thanks in advance.
Nick~
nsamaster0414 is offline
post #2 of 10 Old 07-03-2005, 11:43 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Keep your foot out of the skiny pedal
Make sure your tires are not under inflated
A correctly tuned engine
A wheel alignment
Even an oil change
LT1CJ7 is offline
post #3 of 10 Old 07-04-2005, 12:13 AM
tbicj7
Also, make sure it can breath
Vegore the Wonder Tomato 83 CJ7 TBI 350 smog legal conversion Bowtie stage 3 700r4 D300 w/twin stick Dana 44's front and rear 4.56's locked up at both ends high angle drivelines f/r Xtreme offroad high steer conversion currie steering box brace all custom SS braided lines 37" MTR's warn XD9000i SOA wrangler springs(all rears)slickrock hangers currie bumpers front and rear w/full size spare, full family cage simpson harnesses and tuffy boxes. The list goes on and on.
R.I.P.
08 on the way
tbicj7 is offline
post #4 of 10 Old 07-04-2005, 09:36 AM Thread Starter
nsamaster0414
I have kept it tuned up. I do an oil change around ever 2,200. I used Lucas Oil Stabalizer with it, some STP oil burn treatment plus the reg oil. It gets around the 10-12 MPG that I have read to be common and average, but I am just looking for anything else that might help it. What about a higher engery coil for better combustion or are there any other after market items or such that I might be able to use to help it out a bit. Thanks!
Nick~
post #5 of 10 Old 07-04-2005, 09:40 AM
ravinhuxley
If you havent done TFI or HEI, do it. It helps. I know I gained a bit.
'85 CJ-7
258|T-176|TFI|Weber 38 DGES w/Spacer|2" body lift|Centerforce clutch|A20|D30|32" BFG MTs|Red, of course
ravinhuxley is offline
post #6 of 10 Old 07-04-2005, 01:24 PM
TheJunkMan2005
Try replacing the gear oil with some really good synthetic fluids. Also what size tires are you running? A bigger tire will drop the RPM and increase fuel milage.
On my pick up trucks, I tried putting an open air filter on it, and every time noticed a 2-3mpg drop! Put stock air filter back on, and it'll go right back up. That has happened on my 86 Dodge, 85 Chevy 3/4t 2wd, and my 85 GMC 3/4t 4x4. Consider that also.. Sometimes too much air has a bad effect on fuel milage.
On my GMC, I tried a tornado that I got for free. Dropped fuel milage about 1mpg. I removed the tornado, and took out the air filter, and got that truck upto 14mpg(from 8 when I started a 1200mile trip).
That's just a few little tips I've found for other vehicles.
1988 Wrangler 89000 miles, no rust, no rot, all nice and pretty.. Runs down the highway really nice too.. This is great fun.
TheJunkMan2005 is offline
post #7 of 10 Old 07-05-2005, 12:14 PM
twmattox
Make sure your speedo gear is correct. A lot of times, people will put on larger tires and not correct the speedo. This causes it to register far fewer miles than are actually travelled. This plummets MPG.
Make absolutely certain that your Weber is properly tuned. These can be tuned to act properly, but realy be running rich. Google Weber tuning for guides...
twmattox is offline
post #8 of 10 Old 07-05-2005, 01:53 PM
jeepskate
'Jeep' and 'fuel economy' in the same sentence and it isn't a joke?
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #9 of 10 Old 07-05-2005, 07:17 PM
bjf498
bjf498's Avatar
1983 CJ7
i get about 14 in the city with my fresh motor
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
post #10 of 10 Old 07-05-2005, 09:56 PM
dawgates
1980 CJ7
Did I read that right?? "nsamaster0414" you're only getting (or was) 10-12 mpg with a 258? I know like "jeepstake" says about fuel mileage and Jeep shouldn't be in the same sentence.
But I'm feeling damn proud to be getting 10 mpg with my 360!
Have to tried shaving a few thousands off the cylinder head? This is an old trick to raise the compression. .060 doesn't seem like much, but that could raise the ratio almost a 1/2 point, so from 8 3/4 to 9 1/4 compression ratio. That'll give you a few extra ponies.
You could save also some coin and do the 4.0 liter head and injection swap. That would be cool too. Best of both worlds! Compression and injection.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
Iron Duke Fuel Economy cracked91 Jeep CJ Forum 10 05-28-2009 12:33 AM
CJ-2 and CJ-3 fuel economy papogi Jeep CJ Forum 5 07-16-2008 11:26 PM
fuel economy sailkid Jeep CJ Forum 4 05-17-2006 09:45 PM
4.0 head, fuel economy eprobe Jeep CJ Forum 2 08-10-2004 05:52 PM
258 fuel economy eprobe Jeep CJ Forum 15 07-13-2004 05:23 PM
