fuel economy - JeepForum.com
post #1 of 16 Old 08-30-2011, 06:23 PM Thread Starter
sublimesurfer
fuel economy
Any tips on increasing my fuel economy on my 82 CJ7?
sublimesurfer is offline
post #2 of 16 Old 08-30-2011, 06:30 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Common suggestions typically include:
  • Run smaller tires (same as, or closer to stock size)
  • Lose weight (winch, hard top, large bumpers, etc)
  • Use a stock suspension height (ie: no lift)
  • Use a transmission with a 5th gear
  • Be sure that your carburetor and ignition systems are running right
  • Keep the tire pressure to the maximum reccomended, or a few pounds more
edit..
There's also the issue of driving without a top verus a full top. I would think a hard top probably gives you less wind resistance, but clearly the weight of the top isn't going to help at all. Maybe a full soft top is the right balance.
Another item is lowering the elctrical load (lights, accessories, etc), but in the grand scheme of things it's probably not a huge factor.
Keep in mind the original MPG for CJs wasn't ever great to start with
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #3 of 16 Old 08-30-2011, 07:04 PM
JeepsOLot
Buy a Compass, Sorry, couldn't resist!
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #4 of 16 Old 08-30-2011, 08:20 PM
benullman
1981 CJ7
drive it nicely. Dont have your foot in it. Its not a race car. Shift smoothly and know how to drive a clutch correctly and you will be repaid. My buddy gets 19MPG with a weber 32/36 258/T176 33's 4" lift and full hard top/doors
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #5 of 16 Old 08-30-2011, 11:37 PM
Rollbar
1984 CJ8
It's like driving a brick. Put the windshield down
P.S. 258/4spd/d-300/carter bbd/ 31"tires/3:31 gears/new ign/new timing chain/new vapor canister/rebuilt carb timing @ 12* (due to elevation)/new copper plugs/ford cap/rotor/wires/coil/new fuel tank sender/new hoses......
Getting 15 to 16mpg running 90 octane
I do need to check Peaches air pressure.
<----Click
<---- Click
Rollbar is offline
post #6 of 16 Old 08-31-2011, 03:01 AM
John Strenk
John Strenk's Avatar
1976 CJ5
edit..
Also try
Passenger Car tires.
Electric cooling fan. (saves on HP lost with mechanical fan and only runs when needed. )
Synthetic lubrication in tranny and axles.
Slow Down.
Leave for work when traffic is least busy.
Don't idle long
Drive as soon as engine will pull jeep
Make sure choke is working. Fully open fast depending upon temp.
Run a water heated intake manifold.
Unlock hubs
Adjust brakes.
John Strenk is offline
post #7 of 16 Old 08-31-2011, 03:17 AM
John Strenk
1976 CJ5
edit..
Also try
Slow Down.
Don't idle long
Unlock hubs
Adjust brakes.
post #8 of 16 Old 09-05-2011, 12:51 AM
Astrodokk
Location: Sonoma County, an hour north of San Francisco in wine country.
Tow it behind an RV. Other than that, good luck! I've quit trying myself. I catch myself looking at the gas gauge like every few minutes to see how far the needle moved!
2000 Jeep WJ Grand Cherokee Limited, Black/Black, 4.7L
Astrodokk is offline
post #9 of 16 Old 09-05-2011, 06:08 PM
yahwhy
1982 CJ7
only drive downhill, in neutral with engine off
yahwhy is offline
post #10 of 16 Old 09-05-2011, 06:21 PM
CherryCj7
1979 CJ7
I dont know what engine you have but when I put in my 4.3 I had more power and I get better gas mileage with my 31" M/T tires than with my 29" stock tires. I think the difference of 17 MPGs to 15 MPGs. So if you have a v-8 if you are running the stock size if you increase it reasonably you may get a little better... This is just through personal accounts, i am not even 100% sure about why this is. Hope this helps. - Vince
CherryCj7 is offline
post #11 of 16 Old 09-05-2011, 07:19 PM
BagusJeep
1981 CJ7
Fill in your profile with all the info on your Jeep, anyone can then chime in with comments like 'those 37" swampers are not good for economy"
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #12 of 16 Old 09-05-2011, 07:20 PM
BagusJeep
1981 CJ7
If you have a 258ci mainly stock CJ7 with 31" maximum tyres you should see the high teens in highway driving at up to 60mph. Anything faster, larger etc. will suck the petrol
post #13 of 16 Old 09-06-2011, 04:05 AM
keith460
Jeep. There's Only One
keith460's Avatar
I did that once with my wife's 84 CJ-7 and almost crashed the Jeep on the guardrail. Forgot the steering wheel would lock if the key was turned to the off position. Yikes!
Never did that again....
1984 CJ-7 Renegade
keith460 is online now
post #14 of 16 Old 09-06-2011, 08:30 AM
Cutlass327
1978 CJ5
Was your speedo gears matched for the increase in tire size? If not, it will show fewer than actually traveled miles, not actual mileage, and this will make you think you have increased MPG.
Rick
Cutlass327 is offline
post #15 of 16 Old 09-06-2011, 10:49 AM
CherryCj7
1979 CJ7
The gear was not replaced but i have compensated by adding 6 miles per 100 miles shown on the odometer.
CJ-2 and CJ-3 fuel economy papogi Jeep CJ Forum 5 07-16-2008 10:26 PM
fuel economy sailkid Jeep CJ Forum 4 05-17-2006 08:45 PM
Fuel Economy nsamaster0414 Jeep CJ Forum 9 07-05-2005 08:56 PM
4.0 head, fuel economy eprobe Jeep CJ Forum 2 08-10-2004 04:52 PM
258 fuel economy eprobe Jeep CJ Forum 15 07-13-2004 04:23 PM
