Fuel Delivery Problems!! I've tried everything.... - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Fuel Delivery Problems!! I've tried everything....
Unread 09-25-2011, 12:47 PM   #16
Transorange
1979 CJ7
ok the pump works, the fuel bowls are not stuck, no pressure in the fuel tank, clean fuel filter, lines are clear and not twisted. Oh and the fuel pump works ALL THE TIME??
So the tank is all what´s left.
[SIZE="2"][B]Jeep CJ7[/B][/SIZE]
[SIZE="1"]350sbc, SOA, Fiberglass body, 35s [/SIZE]
Transorange is offline   Reply With Quote Quick reply to this message
Unread 09-25-2011, 12:54 PM   #17
mannyfresh
1981 CJ5
Looked up around the sending unit and the gas line got pinched on the frame when I put the gas tank back up. Dropped the tank enough to get the line free. Just took her around the block and let it run for about 20 minutes. That had to be it. Keeping my fingers crossed she fires up tomorrow! Thanks so much for everyone's input... couldn't have done it without ya'll.
mannyfresh is offline   Reply With Quote Quick reply to this message
Unread 09-25-2011, 03:06 PM   #18
mashunitjeep
1991 XJ Cherokee
maybe flush both lines just take both off sea foam and a air comp and blow all the crap out to rule out the lines
mashunitjeep is offline   Reply With Quote Quick reply to this message
Unread 11-16-2011, 02:49 PM   #19
hankedank05
1983 CJ7
how far did you space the tank from he end bolts and bolts up to the cross frame? did you use lock washers and regular too? my lines kincked whenever i put the tank back up. oly lettin me drive down the street and back.
hankedank05 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2011, 03:41 PM   #20
Momsworry
1979 CJ5
Fuel Problems
I had a similar problem with a Triumph TR-6. Car would run great then all of a sudden either shut down or sputter with no power. I tried everything and nothing worked until I discovered whoever worked on the fuel system before I had it used a gasket sealer that was not "gas compatible" on the sending unit. The gas breaks down the non gas compatible gasket sealer into small globs which then floats around in the tank. Eventually they find their way to the fuel line and or filter and plug it up. Sometimes they will break loose and the car would run great again, then stop or sputter due to clogging. I fixed it by removing the tank, removing the sending unit, cleaning everything including all the old gasket sealer. I reassembled using something like Permatex® Indian Head® Gasket Shellac Compound including the fuel line connections. Hadn't had a problem since.
Momsworry is offline   Reply With Quote Quick reply to this message
Unread 11-16-2011, 06:12 PM   #21
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
There is a divot in the frame crossmember on the side where the gas line has to run or it will pinch off. it gets lots of us.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
cj5 , filter , fuel , pump , start problems
