Fuel Delivery Problems!! I've tried everything.... - Page 2 - JeepForum.com
post #16 of 21 Old 09-25-2011, 11:47 AM
Transorange
1979 CJ7
ok the pump works, the fuel bowls are not stuck, no pressure in the fuel tank, clean fuel filter, lines are clear and not twisted. Oh and the fuel pump works ALL THE TIME??
So the tank is all what´s left.
Jeep CJ7
350sbc, SOA, Fiberglass body, 35s
Transorange is offline
post #17 of 21 Old 09-25-2011, 11:54 AM Thread Starter
mannyfresh
1981 CJ5
Looked up around the sending unit and the gas line got pinched on the frame when I put the gas tank back up. Dropped the tank enough to get the line free. Just took her around the block and let it run for about 20 minutes. That had to be it. Keeping my fingers crossed she fires up tomorrow! Thanks so much for everyone's input... couldn't have done it without ya'll.
mannyfresh is offline
post #18 of 21 Old 09-25-2011, 02:06 PM
mashunitjeep
1991 XJ Cherokee
maybe flush both lines just take both off sea foam and a air comp and blow all the crap out to rule out the lines
mashunitjeep is offline
post #19 of 21 Old 11-16-2011, 01:49 PM
hankedank05
1983 CJ7
how far did you space the tank from he end bolts and bolts up to the cross frame? did you use lock washers and regular too? my lines kincked whenever i put the tank back up. oly lettin me drive down the street and back.
hankedank05 is offline
post #20 of 21 Old 11-16-2011, 02:41 PM
Momsworry
1979 CJ5
Fuel Problems
I had a similar problem with a Triumph TR-6. Car would run great then all of a sudden either shut down or sputter with no power. I tried everything and nothing worked until I discovered whoever worked on the fuel system before I had it used a gasket sealer that was not "gas compatible" on the sending unit. The gas breaks down the non gas compatible gasket sealer into small globs which then floats around in the tank. Eventually they find their way to the fuel line and or filter and plug it up. Sometimes they will break loose and the car would run great again, then stop or sputter due to clogging. I fixed it by removing the tank, removing the sending unit, cleaning everything including all the old gasket sealer. I reassembled using something like Permatex® Indian Head® Gasket Shellac Compound including the fuel line connections. Hadn't had a problem since.
Momsworry is offline
post #21 of 21 Old 11-16-2011, 05:12 PM
Mike Romain
There is a divot in the frame crossmember on the side where the gas line has to run or it will pinch off. it gets lots of us.
Mike
Mike Romain is offline
cj5 , filter , fuel , pump , start problems
Anyone Had This Happen? (Fuel Delivery) texas_campers Jeep CJ Forum 6 01-17-2011 03:40 PM
Fuel Delivery Issues 58D_CavScout Jeep CJ Forum 4 11-14-2010 12:25 PM
Fuel delivery problems, charcoal canister Gummo Jeep CJ Forum 8 11-14-2009 04:04 PM
fuel delivery problem oldskull44 Jeep CJ Forum 8 06-09-2009 10:55 AM
CJ7 - seams like fuel delivery????? jeepnsam Jeep CJ Forum 5 09-11-2006 01:23 PM
