frozen shifter - JeepForum.com
post #1 of 13 Old 12-23-2009, 10:55 AM Thread Starter
CooterBrown
CooterBrown's Avatar
1965 CJ5
frozen shifter
so again my little cj brings me a surprise in the cold. she doesnt have any problem starting first try in 0-10 degree weather but it seems like the shifter does, i had to let it warm up for about 15 minutes before i could get it out of reverse (i dont have a parking break so rev is) is this the norm, or is there somethign i can put on it to make relieve the. i just felt like i was gunna snap the shifter off. but then again its parked right next to my 2010 so i can always just take it but then i feel bad haha
CooterBrown is offline
post #2 of 13 Old 12-23-2009, 12:13 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Two things come to mind and I am guessing here so IMHO.
1) Gear Lube is too thick for the area you live in.
2) Water in the gear lube and it is getting up and around the shift ball and freezing.
You said CJ so my first thought is thick gear oil but you will have to have it checked and see.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #3 of 13 Old 12-23-2009, 12:52 PM Thread Starter
CooterBrown
1965 CJ5
im running 75-90 wich is what they recomended to me. its almost like it compeltely siezes up like no movement at all and then after it runs for a few minutes with the clutch pressed in it works fine?
post #4 of 13 Old 12-23-2009, 01:20 PM
kirkhbauer
Im bellow zero in utah and have somewhat the same problem. mine is do to a bad shift boot alowing water to get into the shift rails and shift tower. Ai have since replaced my boot but I was always able to rock it back and forth "letting clutch in and out" and it came free..Might need to kick the new car out of the warm garage and let the Cj thaw out. if it does not them its internal, like a stuck or bound shift fork
Life's to short to be stuck behind a desk!
kirkhbauer is offline
post #5 of 13 Old 12-23-2009, 01:29 PM
nshefbuch
1982 CJ7
i had the same problem before and it was to thick of gear oil. try a high grade 40w.
nshefbuch is offline
post #6 of 13 Old 12-23-2009, 02:08 PM
Scrambler82
1982 CJ8
0-10 degrees ! If only for a day or two may not be a problem but if you have those temps for extended periods I am not sure if the 75-90 is a good choice.
How about switching to a synthetic of equivalent rating ?
Better in the cold for both the trans and the arm.
Also, like was said do you wheel this in water, if so start checking seals and gaskets.
Just thinking back when I had a Mustang and I rebuilt the trans, I thought I did a great job and basically I did but I had forgotten to torque the front seal retainer bolts which also held in the main shaft; the bolts loosened up after a few power shifts and didn’t allow the shift forks to function properly.
So thinking on this same lines, did you do any work on the trans lately, maybe a loose mounting bolt, maybe a rear mount not tight (misalignment).
Again, i am just throwing out ideas.
Scrambler82
post #7 of 13 Old 12-23-2009, 03:04 PM
mcurcio1989
1976 CJ7
this can happen if your transmission is to full of oil. I a not sure why but it happened to me (filled it in the cold) You may want to check the level.
Disregard everything i say
I have a dana 30 front axle and amc 20 rear if anyone is looking. Both are 3.54, drums, narrowtrack.
mcurcio1989 is offline
post #8 of 13 Old 01-12-2010, 01:42 PM Thread Starter
CooterBrown
1965 CJ5
i know its not too full of oil, because i just checked it not too long ago, buts its really wierd its not stiff if rock hard like its completely locked up. then its get smoother then after its warmed up its fine. once i get back from this patrol, im gunna put her new volt reg in it so old girl will actually start to get her in my garage and drain it maybe try some synthetic or something a little thinner. is there a way to check the gasket, i have wheeled her in water a little not like snorkeling or anything but some big ditches and stuff. and mud. any advice or stories as to what you did would help./
post #9 of 13 Old 01-12-2010, 03:23 PM
nshefbuch
1982 CJ7
wow you haven't fixed this yet? just change the oil and/or use a thinner oil. 5 minutes of your time and this could be done. i had the same problem and it eases up because the oil heats up as you're driving.
post #10 of 13 Old 01-12-2010, 09:52 PM Thread Starter
CooterBrown
1965 CJ5
yea my ship has been underway in and out the past couple weeks and the last time we were home i went and was going to drain the tranny. but she wouldnt start so i spent the weekend figuring that one out. good times. so now that i got the parts to fix that on the way im moving back a project to finish haha. gotta love old crap.
post #11 of 13 Old 01-12-2010, 10:53 PM
80cj
80cj's Avatar
1980 CJ5
I don't know much about cold weather related problems but would hitting the trans case with a hair dryer or heat gun help?
80cj is offline
post #12 of 13 Old 01-14-2010, 11:17 AM Thread Starter
CooterBrown
1965 CJ5
yea that would work but i would have to do it every time i started it. and that would suck
post #13 of 13 Old 01-17-2010, 07:31 PM
Trigger1
1981 CJ5
I just had this problem with mine last week. Mine had a bunch of sand/dirt/water that was frozen where the shifter connects to the linkage. My shifter ended up breaking off one of the tabs. You might want to pull your shifter an plate on top of the tranny and check.
Trigger1 is offline
What is the thread size of the manual shifter and 4wd shifter? HHICJ7 Jeep CJ Forum 7 09-25-2009 12:05 PM
Transfer case, the big shifter, the little shifter, and oddness senaTTor Jeep CJ Forum 10 10-17-2006 06:52 PM
Frozen choke Jeepingrueven Jeep CJ Forum 2 02-27-2006 11:03 AM
Freeing frozen tie rod 80cj Jeep CJ Forum 4 05-02-2004 06:49 PM
New T176 shifter pins and shifter fork!! sampson9dk Jeep CJ Forum 0 06-17-2003 02:20 PM
