front wheelbearing locknuts...please help - JeepForum.com
post #1 of 6 Old 06-24-2002, 02:34 PM Thread Starter
LaredoMan
Post front wheelbearing locknuts...please help
how do you get the front wheel bearing nuts off the front spindle on a 82 cj7? i think its a 2"1/16 deep well socket. but i cant find one of those anywhere. last time we had to use a chisel and hammer. please help. thanks.
84 cj7 laredo
LaredoMan is offline
post #2 of 6 Old 06-24-2002, 04:34 PM
Boggy Bottom
Post
One word: NAPA
Ol' Boggy Bottom
'83 & '84CJs, '51, '53, and '57 Willys Pickups
Boggy Bottom is offline
post #3 of 6 Old 06-24-2002, 10:00 PM
only in a jeep cj
Post
I have never had to use a socket on these before. Wipe away the greese and you should see where the tab behind the first washer is bent up on one section. I use a hammer and chisel or an old socket extension and flaten this out. Then a set of channel locks will turn the first nut. Most likely there will be a groove where a past mechanic has tapped it with the ol' hammer and chisel trick. You may need to do the same. When your putting it back together, it's OK not to fully tighten the inner nut as the outer one finishes putting the preload on the bearings.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 6 Old 06-24-2002, 10:01 PM
only in a jeep cj
Post
Ed
1975 CJ-6 1983 CJ-8
post #5 of 6 Old 06-24-2002, 10:32 PM
Hippo393
Lightbulb
I just got done packing my bearings and had little luck with pliers/channel locks. The nut was chewed up from the pvs. owner. I used a screwdriver and hammer. Later I saw the appropriate tool available at 4WD Hardware for 10 bucks, but NAPA or other parts store will likely have them also.
Buy new nuts (for next time) and the wrench. Having the right tool can help with ease of subsequent jobs (which you know should be done periodically anyway). Plus, if you ever sell your Jeep, the buyer knows you took care of it which helps substantiate your asking price. <img border="0" title="" alt="[Wink]" src="wink.gif" /> There are always tools that go with a sold vehicle, and that's one of 'em.
As far as how hard to torque/hammer 'em, ya got me there.... My Chilton's manual doesn't have "finger tight" as a legitimate torque measurement.
Hippo393 is offline
post #6 of 6 Old 06-25-2002, 10:38 AM
Jeep Daddy
Jeep Daddy's Avatar
Post
When I tighten them, I keep tightening until I feel resistance while spinning the spindle then back off slightly. Then I take a rubber mallet and whack it a few times to make sure the bearings are seated. Then I retighten until I feel resistance and back off again slightly until the resistance is gone. Lock her down and bend the tab. Recheck. You don't want any resistance or you will burn up the bearing prematurely.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
Front Turn Signals and Front Emergency Flashers Out - 1977 Jeep CJ7 mrdibbles Jeep CJ Forum 3 05-25-2009 05:28 PM
Front Bumper May Rub Front Tires? Hybrid Jeep Jeep CJ Forum 6 04-15-2008 10:21 AM
Front differential cover replacement/Front Axle mattmosman Jeep CJ Forum 2 09-18-2006 06:54 AM
replaced front grill, front blinkers won't blink NJCJ7 Jeep CJ Forum 5 11-12-2003 02:04 PM
