front turn signals - JeepForum.com
post #1 of 14 Old 08-18-2011, 11:19 AM Thread Starter
scrappycj5
1976 CJ5
front turn signals
Maybe I am not asking the right question in search , But I am trying to find what to look for when my rear turn signals work fine but the fronts do not work. The front parking lights work but nothing blinks in the front when I put the turn signals on ?
Ideas ?
scrappycj5 is offline
post #2 of 14 Old 08-18-2011, 11:36 AM
bamasteeler
Make sure the screws are grounding good into the body.
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #3 of 14 Old 08-20-2011, 08:35 PM
james04si
james04si's Avatar
1977 CJ5
Any chance they get brighter when you apply the brakes? If so make sure your hazards are completely out.
james04si is offline
post #4 of 14 Old 08-21-2011, 04:21 PM Thread Starter
scrappycj5
1976 CJ5
The grounding screws are fine, parking lights work fine. it seems I am not getting power to the green/white wire which is the left blinker, and no power to the solid green wire which is the right blinker. what would cause that ?
post #5 of 14 Old 08-21-2011, 04:49 PM
james04si
james04si's Avatar
1977 CJ5
Might be the actual turn signal switch in the column or the plug under the dash where it plugs into the harness. Also did him make sure your hazard button is fully pulled out?
post #6 of 14 Old 08-21-2011, 06:02 PM Thread Starter
scrappycj5
1976 CJ5
the turn signal switch is new, but will check it and the plug. The rear blinkers are working fine. also, it looks as if the front blinkers also make the lights in the dash work, I think. I been studying the wiring diagram and thats how it looks. the hazzard is pulled out, I checked that.
post #7 of 14 Old 08-21-2011, 07:04 PM
james04si
james04si's Avatar
1977 CJ5
If I remember correctly power starts at the turn signal flashed. From there it goes to the turn signal switch. Front and rear signals are completely separated from that point on. Once down the column it splits the indicators for the dash from the front lights. So if dash works the harness under the dash should be good too. Next it goes through the firewall and splits to the grill and the fenders. The grill provides the ground for both the fender and grill signals. The dash light gets its ground through the dash.
post #8 of 14 Old 08-21-2011, 10:05 PM
Matt_G
1979 CJ5
your your front side markers signal but not the front lights? it has to be a ground issue then, maybe try scrapping a little paint where the light bucket is contacting the grill, and make sure the screw is touching metal, no paint between it and the grill.
if thats not it, get a test light and figure out where you are not getting power
"This isn't mud, it's a special Jeep Wax"
Matt_G is offline
post #9 of 14 Old 08-22-2011, 12:54 AM
sanddrag
The front side markers blink? Really? If mine don't what does that mean? They are not grounded? (because of my recent repaint).
sanddrag is offline
post #10 of 14 Old 08-22-2011, 02:00 AM
John Strenk
John Strenk's Avatar
1976 CJ5
If hooked up as originally made then yes, the front side markers will flash.
The front side markers are NOT grounded. In fact if they are, they will not flash. The only reason for the fenders to be grounded is for the ground for the grill.
Scrappy, do your dash lights TS indicators Work? or did you just deduce that they should.
I would get a test light and check the TS plug into the harness.
here is my favorite TS post:
First of all, familiar yourself with the mechanism inside the column. Here is a link to an ignition cylinder replacement but the same dis-assembly process is followed for troubleshooting some turn signal problems.
http://civilianjeep.info/Strenk/Stee...placement.html
Do you have tilt or non-tilt steering? Just what is your signal doing or not doing??
Here is a good discussion on turn signal switch:
http://www.jeep-cj.com/forums/f7/tur...p-please-8872/
Here is a little bit of info on the insides
Here is what you would see if you pull off your steering wheel and locking plate.
This one is missing a cancelation spring and would not turn off when the wheel came back to center. THe spring had rusted off some time after it got all wet.
Here are were both springs are located:
The best thing to do is to flush out a lot of the dirt with contact cleaner.
There are a couple of springs on the top that keep the switch in the right position until you return the steering to center after a turn and another spring to keep pressure on the contact pad.
It wouldn't hurt to put a little moly grease on here after you clean the switch.
If you would to take it apart, something I DON'T recomend, you will see the contact pads on one part:
You can see were the different contact pads go.
This is the wiper arm. Looks rather complicated at first.
There are some small springs that insure contact.
Get some mud or if the springs rust away, you got problems.
The wipers work like this:
In the center position the rear lights are connected to the brake switch contact:
Turn the lever to the right and the right rear light is now connected to the TS flasher pad and also with the front right light. THe left rear light is still connected to the brake switch:
Turn it to the left and just the opposit happens. The left rear light is now connected to the TS flasher pad and also with the front left light. THe right rear light is still connected to the brake switch:
[IMG]http:/www.civilianjeep.info/Strenk/TurnSignal/TSWiperConnectionLeftTurn.jpg[/IMG]
You can see how dirt can just screw things up in here.
Now your probably wondering what that little extra pad on the right is for.
Well it's for the hazard lights.
Here is what it looks like on the back:
Here is what the contacts look like:
These short the front and rear lights together and connect it to the hazard flasher by making contact with the connections on the back of the turn signal switch:
you can see the plastic shield with the holes to make contact.
It effectively connects these points:
Here are some wire connections but I notice the color codes are not standardized. The several TS switches I have are all different but the locations are all in the same place:
You can see some more detail here if your poking around with a meter or test light:
Here is the plug on the end of the switch:
It plugs into the harness like this:
What's that Orange wire on the far left? I think it's for illumination for the PRNDL indicator if you have an automatic.
On this one I broke the insulation on the wires because they are so old.
Here is a simple schematic of the whole mess:
Sorry for the long post....
John Strenk is offline
post #11 of 14 Old 08-22-2011, 04:04 AM Thread Starter
scrappycj5
1976 CJ5
the dash turn signal indicators are not working. nothing up front blinks. when I put on the parking lights all the front lights work fine. the only thing that is not working is the front turn signal lights and the dash t/s indicator lights.
I did install a brand new turn signal switch a few months ago when I started replacing stuff to get things to work. I have also install new flashers, both hazard and blinker.
post #12 of 14 Old 08-22-2011, 08:25 AM
John Strenk
1976 CJ5
Well if the dash indicators and the front TS lights don't work and the rear ones do work then the 'disconnect has to be at the plug on the steering column or the TS switch itself. I'm betting on the TS plug is not pushed together all the way. There were two styles of plugs out there if I remember. the TS from my 76 harness did not fir my 84 harness.
Get a test light and plug it into the column plug connections and see if your getting power to the column plug.
post #13 of 14 Old 08-22-2011, 09:45 AM Thread Starter
scrappycj5
1976 CJ5
Thanks John, I will check it out. The turn signal switch I bought I am pretty sure it was for my year, but will check to make sure to see if everything is making contact.
post #14 of 14 Old 08-29-2011, 03:25 PM Thread Starter
scrappycj5
1976 CJ5
Well I ended up ordering a new trun signal switch. The one I had put in was faulty. not sue how but I tried a brand new one and everything works.
Thanks for the info.
turn signals on front parking lights SToth66cj5 Jeep CJ Forum 8 02-09-2011 05:20 AM
NO Turn signals with L.E.D.s Front and Rear xtremdude Jeep CJ Forum 4 09-15-2010 12:16 PM
Front driver turn signals not working VanillaXtract Jeep CJ Forum 0 08-25-2010 09:50 AM
Front Turn Signals and Front Emergency Flashers Out - 1977 Jeep CJ7 mrdibbles Jeep CJ Forum 3 05-25-2009 05:28 PM
LED front turn signals...Pics?? cj7kevin Jeep CJ Forum 2 03-04-2008 10:41 PM
