Front shackle suggestions - JeepForum.com
post #1 of 14 Old 05-12-2013, 11:18 AM Thread Starter
Jamesromeos
1979 CJ5
Looking to replace my front shackle as my jeep has a mild lean in the front. A while ago someone suggested a .5" shackle lift. I have heard of crabtree tool and die, any other suggestions or is he who to go with? Pics of the shackles on some cj's would be helpful.
Jamesromeos is offline
post #2 of 14 Old 05-12-2013, 11:50 AM
Dngrs1
1979 CJ7
Jeep lean??? Nah, can't be.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #3 of 14 Old 05-13-2013, 06:16 AM
cj5huntingrig
1974 CJ5
You probably have a twisted frame or bent leaf springs. The leaf springs are easy to replace. Bent frame is more of a pita. Any aftermarket shackles are better than the originals. I have the warrior products lift shackles and love them. If you are considering lifting just one corner, I would urge you to reconsider fixing the actual issue.
Tx. E
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #4 of 14 Old 05-13-2013, 06:29 AM
Caish
1987 XJ Cherokee
Just remember that adding length to the shackles also changes the axle castor and you can create a drive issue....
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #5 of 14 Old 05-13-2013, 10:02 AM Thread Starter
Jamesromeos
1979 CJ5
I just put a brand new bDS lift in, its not the springs or frame. Will .5" really effect the driveline that much?
post #6 of 14 Old 05-13-2013, 10:08 AM
ASteve
1972 CJ5
Yes, Jim Crabtree would be the go to go to!
Here's a few shots of my Crabtree shackles:
Not sure what's up with JF right now but it's saying my files are too big...did something change that I'm not aware about?
anyways, Here's a link to the photos:
http://www.jeepforum.com/forum/f8/da...l#post12585991
http://www.jeepforum.com/forum/f8/da...l#post13912998
ASteve is offline
post #7 of 14 Old 05-13-2013, 10:20 AM
Renegade82
1982 CJ7
1/2"? No. But when you combine it with a lift spring it can make it worse. Some springs don't put flat spots in the arch. I had a 1 1/4" shackle lift with a 1 1/2" add-a-leaf setup for years and never had any steering issues, until I swapped out the add-a-leafs for some 2 1/2" RC. springs. Then I needed some shims to correct the problem.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #8 of 14 Old 05-13-2013, 12:36 PM
Dngrs1
1979 CJ7
To correct 1/2" you will need a 1" longer shackle. Having a 1" longer shackle on one side may be more visibly obvious than a 1/2" lean.
Dngrs1 is offline
post #9 of 14 Old 05-14-2013, 05:45 AM
cj5huntingrig
1974 CJ5
Oops. I misunderstood and thought you were leaning to one side. Ill swallow my pride now. E
post #10 of 14 Old 05-14-2013, 07:41 AM
jp360cj
1977 CJ7
If the springs are knew they may level out once they settle in
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #11 of 14 Old 05-14-2013, 10:35 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Throw about 300 pounds of weight in the very back, it should settle down.
Matt
Matt1981CJ7 is offline
post #12 of 14 Old 05-14-2013, 11:58 AM
Dngrs1
1979 CJ7
Ditto. When the OP said 'lean' I assumed side to side.
Dngrs1 is offline
post #13 of 14 Old 05-14-2013, 01:57 PM Thread Starter
Jamesromeos
1979 CJ5
No worries, I was unclear....Matt, I have a full size spare, and a back seat and it is still sitting about 3/4" nose down.....
post #14 of 14 Old 05-14-2013, 03:15 PM
ASteve
1972 CJ5
What is the length of your shackles in the rear bolt center to bolt center?
...heck ... what is the front shackle length as well?
Just checking on the photo upload to see if it's fixed or not...photo of Crabtree Shackles
SC
ASteve is offline
