Front and rear axles - Page 2 - JeepForum.com
post #16 of 19 Old 01-08-2012, 08:30 AM Thread Starter
DENVAR03
Here are a few pictures of my set up,for the axle ,please reply with any thing you see,that can help.i will just bolt up as is ,if it is ok.
Thanks
dennis
JANUARY PICTURES 003.jpg   JANUARY PICTURES 005.jpg   JANUARY PICTURES 008.jpg   JANUARY PICTURES 010.jpg   JANUARY PICTURES 011.jpg
DENVAR03 is offline
post #17 of 19 Old 01-08-2012, 08:32 AM Thread Starter
DENVAR03
How do i shrink pics.??.
DENVAR03 is offline
post #18 of 19 Old 01-08-2012, 09:37 AM
gojeepin
1983 CJ7
OK... it's best to measure caster when the vehicle is complete, sitting at ride height (ususally on its wheels), and on level ground.
Often times the stock springs set the caster are right where it needs to be. The perches on a Dana 30 are pretty thick, so if the caster is only off a degree or two, you can mark and carfully grind the perch mounting surface to add the angle required.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #19 of 19 Old 01-08-2012, 09:37 AM
Shiftace
1977 CJ5
Originally Posted by JeepHammer View Post
BEST WAY TO SCREW UP CASTER I'VE SEEN POSTED SO FAR!
You may get the pinion angle right, but you will screw up the caster something awful since you are also rotating the steering knuckles THE WRONG DIRECTION...
With larger tires, you want to ADD CASTER, not take caster out of the alignment.
Yes, we wouldn't want to screw up the caster on that rear end.
Originally Posted by gpets View Post
...it is perfectly acceptable to take a sawzall to anything you can't figure out, that is how we all learn.
Shiftace is offline
Same ratio in front and rear axles? jml141 Jeep CJ Forum 6 02-21-2010 06:07 PM
need help...transfer case? front & rear Axles? morty09 Jeep CJ Forum 6 01-25-2010 08:07 AM
using front and rear axles off a commanche? rusty cj Jeep CJ Forum 0 05-16-2005 07:45 PM
Value of '86 CJ D44 front and rear axles? Robb Kiker Jeep CJ Forum 5 12-17-2004 02:18 AM
front & rear axles swaps, 83 CJ7 RadarRick Jeep CJ Forum 4 11-02-2002 03:22 PM
