front pinion seal - JeepForum.com
post #1 of 3 Old 10-20-2011, 09:14 AM Thread Starter
rbush
front pinion seal
I know this is probably a stupid question, but I can't help it..... I am replacing the pinion seal on the front differential on my 75 CJ. It does not have the crush sleeve, so it looks like a fairly straight forward thing. I have dropped the drive shaft and getting ready to remove the nut that holds the pinion shaft in. So my dumb question is this, how do I lock the pinion shaft to remove the nut. I can lock the front hubs and block the wheels but that seems to be alot of pressure (210 ft/lbs if I read correctly) to put against those hubs. Is there a better way to lock that to remove the shaft?
Please leave off the duhhh, when you answer. I said it was a stupid question....
rbush is offline
post #2 of 3 Old 10-20-2011, 10:12 AM
VACJ7
VACJ7's Avatar
A lot of guys make their own yoke holder. I have also seen one you can purchase. Basically a thick piece of scrap steel, cut a hole in it so you can get a socket on the nut, and drill 4 holes so it bolts to the yoke where the driveshaft usually bolts.
Here is one I saw a while back. But you can definitely make a simple tool a lot cheaper. http://www.ratechmfg.com/Yoke%20tools.htm
'84 CJ-7 |
VACJ7 is offline
post #3 of 3 Old 10-20-2011, 10:48 AM
mrgimble
2015 JK Wrangler
24" pipe wrench works great.
mrgimble is offline
pinion seal peigrand Jeep CJ Forum 7 09-29-2010 03:56 PM
Front pinion seal tcase leak attworth Jeep CJ Forum 1 09-07-2010 05:41 AM
Pinion Seal fireman77 Jeep CJ Forum 2 10-20-2005 09:17 PM
front pinion seal dana30 tolobill Jeep CJ Forum 1 02-08-2005 03:39 PM
Model 30 front axle and model 20 rear pinion oil seal? Paul M Jeep CJ Forum 6 06-08-2003 07:33 AM
