front hub stud replacement - JeepForum.com
post #1 of 6 Old 07-27-2013, 02:09 AM Thread Starter
tjeep1
1978 CJ7
upon rebuilding my dana 30 i find that the 6 studs holding the hub on are weak and stripped,has anyone replaced them without removing the knuckle and just draw them in tight with a nut just like you do a wheel stud????? any input would be great. thanks in advance
tjeep1 is offline
post #2 of 6 Old 07-27-2013, 03:00 AM
dg6772
That's what I did with mine when I changed them
Dave in Muskegon
dg6772 is offline
post #3 of 6 Old 07-27-2013, 09:19 AM
jeepwhore
For the locking hub? Double nutting them will work but if they're loose you might as well pull them out, clean the holes and loc tite them before they go back in. If they came loose once, they'll come loose again.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 6 Old 07-27-2013, 09:39 AM
skizriz
1978 CJ7
I assumed he meant the studs for the spindle.???
Sent from my HTC One SV using JeepForum
skizriz is offline
post #5 of 6 Old 07-27-2013, 11:05 AM
jeepwhore
If thats the case I'd be leery of just sucking them back in. If the teeth on the studs won't grab or are spinning/loose in the knuckle I'd be pulling it apart to inspect it closer and see whats going on with the knuckle.
**Edit, NM, I see now what he's proposing. That should be fine if you have enough room to feed the new studs in from the back.**
post #6 of 6 Old 07-27-2013, 08:17 PM Thread Starter
tjeep1
1978 CJ7
thanks guys i did it today and it worked great,it was the spindle studs and it worked for anyone doing it them self
tjeep1 is offline
