front hub stays locked - JeepForum.com
post #1 of 25 Old 07-27-2013, 07:25 PM Thread Starter
Bigun
1980 cj5 w/ dana 30 front and the driverside hub stays locked constantly, noticed this after seeing both axles turning w/ tc in 2H, jacked it up and locked w/ hub not locked and noticed no resistance on trying to lock or unlock hub, now don't know proper names so bear with me, when taking hub cover off the first gear on the spindle is smooth on one end with straight cut gears on other and should be held on the spindle by a small lock ring but the gear seams to slip right over the lock ring, is this my problem? and if so which one to replace? thanks for any help
Bigun is offline
post #2 of 25 Old 07-27-2013, 09:06 PM
LumpyGrits
I would just replace BOTH of those 33 year old hubs.
LG
LumpyGrits is offline
post #3 of 25 Old 07-28-2013, 06:06 AM
thompsoj22
is there routine maint on the locking hubs?
LG
is there scheduled maint on the locking hubs?
thompsoj22 is offline
post #4 of 25 Old 07-28-2013, 06:25 AM
skizriz
1978 CJ7
Just clean them inside and lightly lubricate them as needed.
Sent from my HTC One SV using JeepForum
skizriz is online now
post #5 of 25 Old 07-28-2013, 07:36 AM Thread Starter
Bigun
everythings been cleaned, greased, w/ new bearings and races, would new Warn locking hubs fix my problem?
Bigun is offline
post #6 of 25 Old 07-28-2013, 07:42 AM
Patter
1981 CJ5
D30 shaft should look like this.
Not sure what you meant by smooth?
Hub should be behind snap ring. Should not slip over it.
Hope these phone pics work.
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #7 of 25 Old 07-28-2013, 08:24 AM
jeepwhore
How much grease did you put in the hub? It should only get a light coating, too much and it can cause problems.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #8 of 25 Old 07-28-2013, 11:23 AM
LumpyGrits
OP, there is no way anyone can answer your second question since none of us know what your hub/spindle area are looks like except you.
Do you have a Factory Service Manual(FSM)and I don't mean a Haynes' etc.
Can you post pictures.
IF, your splines etc do not look like what you see in Patter's post, you may have some issues.
LG
post #9 of 25 Old 07-28-2013, 11:25 AM
LumpyGrits
Did you ever get the FSM?
That tells you to service the hubs when the wheel bearings & spindle bearing are serviced.
LG
post #10 of 25 Old 07-28-2013, 12:48 PM Thread Starter
Bigun
everything has been serviced cause I rebuilt this CJ from the ground up and according to the Haynes book cause thats all I got the hub shaft is sliding past the retaining ring, is that keeping my hub locked? if so and not ever dealt with Warn hubs, will Warn hubs fix my problem or is something else wore out? thanks
Bigun is offline
post #11 of 25 Old 07-28-2013, 12:51 PM
ctorj
1977 CJ7
What hubs do you have? Is it the Factory 6 bolt hub? I had this same issue with the factory locking hubs and ended up taking them off to find that someone turned them the wrong way and the plastic Nut inside came off. Its the plastic nut that threads onto the switch part that you turn.
ctorj is offline
post #12 of 25 Old 07-28-2013, 12:54 PM Thread Starter
Bigun
yeah
Bigun is offline
post #13 of 25 Old 07-28-2013, 01:03 PM
LumpyGrits
After 33+ years of use. You want Warn to warrantee your hubs, REALLY.
Confirm you do have the snap ring on the axle stub.
These are the black painted OEM hubs, correct??
Those Warns are junk. Look at Mile Marker, MUCH better than anyone else.
Can you post pictures for us folks to see, what you are talking about???
LG
post #14 of 25 Old 07-28-2013, 01:25 PM
lukenicwalker
1982 CJ7
LG
LG - I think his question was would replacing his existing hubs with new Warn hubs fix his problem, not whether or not Warn would warranty his 33 year old hubs.
OP - photos would certainly help, and I agree with LG on going with Mile Marker. They seem to be a bit higher quality...
ldw
lukenicwalker is offline
post #15 of 25 Old 07-28-2013, 01:29 PM Thread Starter
Bigun
have not said anything about a warranty, yes they are the factory hubs, no I'm not able to post pics
Bigun is offline
