Front grill & Radiator bushing - Page 3 - JeepForum.com
post #31 of 60 Old 02-10-2012, 11:01 AM
GlennLever
GlennLever's Avatar
Well I cleaned up and powder coated the old pieces and I think all I need is the rubber pieces.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #32 of 60 Old 02-10-2012, 11:16 AM
keith460
Jeep. There's Only One
keith460's Avatar
Why are there two washers between the two rubber isolators?
I don't remember having those on mine in that configuration. I have mine setup bottom up with the bolt, lock washer, heavy fender washer, thin bushing washer, rubber isolator, Jeep frame, rubber isolator, washer w/sleeve, grill encapsulated nut.
Which is the correct way.
1984 CJ-7 Renegade
keith460 is offline
post #33 of 60 Old 02-10-2012, 11:35 AM
GlennLever
GlennLever's Avatar
I don't remember having those on mine in that configuration. I have mine setup bottom up with the bolt, lock washer, heavy fender washer, thin bushing washer, rubber isolator, Jeep frame, rubber isolator, grill encapsulated nut.
That was that way it came apart (with the two washers). That does not mean it is correct.
You did not have anything between the top rubber isolator and the grill?
The heavy washers on the inside of my set up "fit" the metal sleve and I believe they were there to correct the height.
And I did not have a lock washer on the bottom, it was a heavy flat washer.
Glenn R. Lever
My Web Site
post #34 of 60 Old 02-10-2012, 12:15 PM
keith460
keith460's Avatar
Left that part out when I first posted, now corrected.
Yes, above the rubber isolator is the washer with sleeve attached.
1984 CJ-7 Renegade
keith460 is offline
post #35 of 60 Old 02-11-2012, 01:27 PM
keith460
keith460's Avatar
NAPA says no go at the moment. They are going to do a search and see what they can come up with and let me know at the end of the week. Plus, the guy I usually deal with was not in today and I may have to wait until he is present in order to use his parts search expertise. That one person has helped me in the past to track down parts that everyone else says cannot be found. Sorta of a hobby for him and he always came through most of the times.
Kinda dealt with a parts monkey today that works the weekend if you know what I mean.
1984 CJ-7 Renegade
keith460 is offline
post #36 of 60 Old 02-11-2012, 02:09 PM
GlennLever
GlennLever's Avatar
I know exactly what you mean. I had the same experience the first time I visited NAPA. The last time I got a "Good" guy who spent time tring to find the part. I bolted the old bushing in today for the time being and will try Mc Master and see if I can come up with one that will work.
Thanks for the effort. If your good guy comes through let me know.
Glenn R. Lever
My Web Site
post #37 of 60 Old 04-07-2012, 12:24 PM
drespecki
1983 CJ7
Any luck on finding the mount yet?
I need one also...
It only hurts while you're breathing..
drespecki is offline
post #38 of 60 Old 04-07-2012, 01:16 PM
GlennLever
GlennLever's Avatar
I need one also...
I ended up reusing the old one. Never found a new one. If you have to you could make one.
Glenn R. Lever
My Web Site
post #39 of 60 Old 04-07-2012, 03:44 PM
chopki1
1981 CJ7
I ordered this kit off ebay. It is poly not rubber but it came with pretty much all the bushings you need. does not have the sleeves and such though. http://www.ebay.com/itm/110815500895...84.m1439.l2649
chopki1 is offline
post #40 of 60 Old 04-07-2012, 05:35 PM
GlennLever
GlennLever's Avatar
Nice.
I wanted rubber as the rest of the mounts on the Jeep are rubber and you should not mix (poly and rubber) as they flex different.
Glenn R. Lever
My Web Site
post #41 of 60 Old 04-07-2012, 05:59 PM
Crazyray2929
1981 CJ7
Hockey pucks...lol...
Crazyray2929 is offline
post #42 of 60 Old 04-24-2012, 08:13 PM
jwhi1979
1979 CJ7
I know this thread is old but I found this bushing while looking for one myself. I dont know if its the correct size or not....
http://www.napaonline.com/Catalog/Ca...006_0131778895
jwhi1979 is offline
post #43 of 60 Old 04-24-2012, 10:44 PM
GlennLever
GlennLever's Avatar
Will you be ordering it? If so would you post back if they are the same size? That would only be half of the two parts needed, Do you have a suggestion for the second part?
Thanks. I was forced to use the original parts when I put it all back together
Glenn R. Lever
My Web Site
post #44 of 60 Old 04-24-2012, 11:00 PM
jwhi1979
1979 CJ7
Im not sure if I will order it or not. I dont know how close it is in size to the original one....
jwhi1979 is offline
post #45 of 60 Old 04-25-2012, 08:36 AM
jeepster4245
1982 CJ5
Call Ryan "the jeep guy"... My bushing dropped out on the trail and I got his info from a previous post..he sent it out right away...friendly and helpful.
Last edited by jeepster4245; 04-25-2012 at 08:38 AM. Reason: lack of coffee and thought process
jeepster4245 is online now
Grill Bushing mount jeepduo Jeep CJ Forum 13 05-11-2014 12:54 PM
A solution / gap between radiator and grill / no room between radiator and fan GlennLever Jeep CJ Forum 6 10-25-2011 12:03 PM
Radiator Fitment / Gap between radiator and front grill GlennLever Jeep CJ Forum 23 10-24-2011 09:07 PM
question on grill and radiator swarren Jeep CJ Forum 2 08-01-2011 10:34 PM
front Grill & radiator mount kponytail Jeep CJ Forum 1 08-17-2010 09:04 AM
