Front end shake...is it the hubs??? - JeepForum.com
post #1 of 4 Old 07-17-2010, 06:40 PM Thread Starter
TheGhost
1983 CJ7
I've completely rebuilt the front end on my 83 CJ-7 (just because it needed it, not to attempt to fix this problem) - had it to the alignment shop - everything is good. I get a slight wobble above 50 MPH - it can be seen and heard. The rims were checked when I had the tires put on (31 X 10.50) and all were straight and the tires balanced pretty well without much weight (less than 1.5 ounces anywhere). Just for grins, I locked the hubs in today and to my surprise, it almost completely went away. So - could it be the hubs????
TheGhost is offline
post #2 of 4 Old 07-17-2010, 09:00 PM
82JeepCJ7
1982 CJ7
With the hubs unlocked, crawl under with a small pry bar and pry up on the front axle U joints at the knuckle. See how much play there is. I had the bearing inside the spindle that supports the axle shaft go out on me before and it allows the axle shaft to droop.
82JeepCJ7 is offline
post #3 of 4 Old 07-18-2010, 08:08 AM Thread Starter
TheGhost
1983 CJ7
I'll check that out today - but, wouldn't that be just the opposite of what I described??? It would seem that if the bearing was bad causing the axle to "droop", you'd get the "wobble" when the hubs were locked in and that axle is turning, not the other way around.
TheGhost is offline
post #4 of 4 Old 07-18-2010, 08:18 AM
josh97
My brothers cj7 had a bad vib at hiway speed..come to find out the front drive shaft slip yoke was bad...The hubs were unlocked but still had enough kenetic energy to turn the front shaft that was causing the driveshaft to move and hense the vibration...
Its a jeep thing...Hell nobody understands!!!!
josh97 is offline
ball joints , death wobble , knuckles , shake , shimmy , steering , steering knuckles , Tie rod end , tie rods , ujoints , wheel bearing , wobble
Dana 44 Front Hubs Get Warm Group_er Jeep CJ Forum 1 06-06-2009 09:22 PM
Locking front hubs for dana 30 dlloyd443 Jeep CJ Forum 7 01-31-2009 09:07 PM
Help please- Bad noise from the front- hubs? Sixcarbs Jeep CJ Forum 5 03-10-2008 07:56 AM
1942 Ford MGW front end shake Sturgell Jeep CJ Forum 2 06-21-2006 10:45 AM
Front hubs hard to turn CJ5_Tom Jeep CJ Forum 7 03-09-2003 09:02 AM
