front end - JeepForum.com
post #1 of 8 Old 05-13-2013, 03:05 PM Thread Starter
dbeebe4125
1983 CJ7
front end
i need an answer please. on my cj7 when i lock my hubs the front end knock and wants to jump even when its not in 4hi or 4lo. it happens when excel or turn right or left
dbeebe4125 is offline
post #2 of 8 Old 05-13-2013, 03:43 PM
Davis77Cj
1977 CJ7
are you on pavement?
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #3 of 8 Old 05-13-2013, 03:44 PM
SLO_Ken
Sounds like you have a locker of some sort in the front differential. Does it do it if you only lock one hub and leave the other free?
SLO_Ken is offline
post #4 of 8 Old 05-13-2013, 07:17 PM
keith460
Jeep. There's Only One
keith460's Avatar
First thing I would check is the condition of the axle U-joints right at the steering knuckles. They will make snap, crackle and popping noises when they are worn or seized.
Knuckle U-joint (ignore the circled item)
1984 CJ-7 Renegade
keith460 is offline
post #5 of 8 Old 05-13-2013, 08:11 PM
82JeepCJ7
1982 CJ7
Its amazing what happens when you put a vehicle in 4wd (even locking just the hubs). So many people think something is wrong because it binds, bucks, etc when on pavement etc.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 8 Old 05-13-2013, 09:09 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
A vehicle with the hubs locked in, but not engaged in four wheel drive at the t case should not bind or buck unless there is a locker, LS, or a problem with the front end. Remember, virtually all modern 4X4's run with the front locked permanently.
As stated above, I would check the U joints. If all is well, then a move to the diff is in order.
jeepdaddy2000 is offline
post #7 of 8 Old 05-13-2013, 09:19 PM
skizriz
1978 CJ7
Yep. Up here in the snow belt we lock in the hubs all winter. Saves the trouble of getting out in the cold when you need 4wd.
Could also be a t-case stuck in 4wd.
Sent from my iPod touch using JeepForum
skizriz is online now
post #8 of 8 Old 05-13-2013, 10:11 PM
titomars
1981 CJ7
Assuming it is all stock the first place I would look is the axle shaft u-joints. If one or both are bad they will start binding and bucking the moment you turn the wheel on pavement. The only other cause that I can think of would be a locker or welded spiders.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
