Front Drive shaft - JeepForum.com
post #1 of 6 Old 07-02-2013, 08:40 AM Thread Starter
prismfisher
1982 CJ8
Front Drive shaft
I have been hearing a noise in the front and have isolated to the frond drive shaft. There seems to be some slop in the (what I am calling ) slip yoke right before the U Joint (which also has to be replaced). My question is.... is the slop acceptable or is there a seal that needs to be replaced? I know there is a zerk on it but what other maintenance needs to be done on this?
Thanks for the input. I just didn't know what terms to search for
prismfisher is offline
post #2 of 6 Old 07-02-2013, 08:53 AM
MoC
The front drive shaft only turns when engaged 4wd. Are you hearing the noise all the time or just in 4wd?
Edit to answear question --> The driveshaft should not have slop in the slip joint. A drive shaft company can fix it.
MoC is offline
post #3 of 6 Old 07-02-2013, 09:20 AM
LumpyGrits
In 2WD, you should NOT hear a thing.
With the shaft now removed. Test drive the Jeep with the hubs locked ans un-locked to confirm the issue is the DS.
LG
LumpyGrits is offline
post #4 of 6 Old 07-02-2013, 10:58 AM Thread Starter
prismfisher
1982 CJ8
Thanks. The noise is all the time and not just engaged. Will look at getting repaired. It is sloppy where the shaft goes into the sleeve and not the u joint itself.
post #5 of 6 Old 07-02-2013, 11:38 AM
MoC
Just to make sure you understood the responses. If the noise is all the time it is not the front drive shaft or front drive shaft u joints.
MoC is offline
post #6 of 6 Old 07-02-2013, 12:34 PM
LumpyGrits
[quote=moc;15632713]just to make sure you understood the responses. If the noise is all the time it is not the front drive shaft of front drive shaft u joints.[/quo
THIS X-2!
LG
