Quantcast Front disc - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Front disc
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 05-12-2007, 06:21 AM   #1
DeltaSigCJ5
1995 XJ Cherokee
Front disc
SO with a 74 CJ5 dana 30 front axle whats the quickest/easiest/cheapest way to do the Front disc conversion?
Hales
DeltaSigCJ5 is offline   Reply With Quote
Old 05-12-2007, 09:08 AM   #2
jayhawkclint
1970 CJ5
If you can find a later CJ being parted out, get the hubs-out assembly on a 6-bolt caliper bracket model ('77-'78, I think) or the knuckles-out assembly on a 2-bolt caliper bracket model ('79+).
Since most of us don't easily come across CJs in the bone yard, next best thing would be to do the Chevy conversion. You're going to need to salvage the caliper bracket, caliper and brake hose off of a '73-'87 1/2 ton Chevy 4wd pickup or K5 Blazer (some models even go up to '91). Next you'll need to buy a pair of 1-1/8" '77-78 CJ5 rotor from a place like Quadratech or Krage's. You'll need to have your hubs machined just a hair, and you'll need new studs for the rotors. Here is a great article:
http://www.earlycj5.com/tech/brakes/diskSwap/disc_conversion.php
The nice thing about the Chevy setup is that you end up with a brake system designed to stop a 6,000lbs+ truck in a Jeep that weighs half that much. Here is a pic of the Chevy setup on a CJ5:
My '70 CJ5 Build Thread:
http://www.jeepforum.com/forum/f22/my-jeep-build-thread-359375/
jayhawkclint is offline   Reply With Quote
Old 05-12-2007, 12:06 PM   #3
Indy
By far the easiest is to just find an axle with discs and swap axles. Quick and relatively painless.
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
Glock Forum
