Quantcast Front differential cover replacement/Front Axle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Front differential cover replacement/Front Axle
Old 09-17-2006, 09:03 PM   #1
mattmosman
Hello all...kinda new to fixing up Jeeps so bear with me. I have a 79 CJ7...to make a long story short I busted up the front differential cover (dana 44) ...not bad but it is leaking pretty good and needs to be replaced. Also damaged my axle where it attaches to the wheel....so now the front driver side wheel will not turn. On a scale of 1-10 how easy would these problems be to fix and anything I should be aware of before I start? Thanks for the help and bearing with a total newbie!
mattmosman is offline   Reply With Quote
Old 09-18-2006, 04:13 AM   #2
jeepdaddy2000
1971 CJ5
Unless someone transplanted a 44 in front you have a 30. Without knowing exactly what the damamge is, it will be hard to troubleshoot. Pictures are a big help here.
jeepdaddy2000 is offline   Reply With Quote
Old 09-18-2006, 07:54 AM   #3
mattmosman
It is defintely a dana 44...I haven't cracked the cover open yet but I believe that is where the damage is
Glock Forum
