Front Axle Pinion Bump Stop Removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Front Axle Pinion Bump Stop Removal
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueEngo winches available at www.rockridge4wd.com! Free shippROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 06-09-2014, 09:12 AM   #1
XJ2CJ
1981 CJ7
On the CJ7, I am doing a SOA setup and was noticing that the frame has some sort of bump stop built in for the front axle pinion. Is this something that is needed for anti-wrap or is it safe to remove? I'm swapping out the front axle for a D44 so I'm not sure that it is in the right place anyways. Just figured that I would ask before breaking out the grinder.
XJ2CJ is offline   Reply With Quote
Unread 06-09-2014, 10:16 AM   #2
LumpyGrits
Remove it for your SOA mod.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 06-09-2014, 11:00 AM   #3
XJ2CJ
1981 CJ7
Sounds good. Saves a little sandblasting.
