Front Axle Breather Question Dana 30 - JeepForum.com
post #1 of 25 Old 05-10-2013, 05:46 AM Thread Starter
CJBADASS
Hello,
Can anyone show me a picture of how the front axle breather tube should be routed on a 1986 CJ7? Mine just goes up to the frame, and is just stuffed onto a hole in the frame. Lastly the breather cap in broken off.
Thanks,
Kevin C
CJBADASS is offline
post #2 of 25 Old 05-10-2013, 05:58 AM
RDH
Most of the time when I replace them, I run it as high up as I can and then loop it back down. Then again, I get into some pretty damaging things in the woods.
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #3 of 25 Old 05-10-2013, 06:18 AM Thread Starter
CJBADASS
Front Axle Breather Dana 30
Thanks for your response. How and where do you run it? Do you attach to the fire wall, just ty-wrap it? do you have any pics? I want to do it correctly, and deffinatly want to keep it away from mud, and water.
CJBADASS is offline
post #4 of 25 Old 05-10-2013, 06:32 AM
billybooster2
1983 CJ8
It attaches directly up to the RHS radiator and secures at the top thereof i believe
billybooster2 is offline
post #5 of 25 Old 05-10-2013, 07:23 AM
CSP
As long as it's up high enough to keep water out there really isn't a wrong or right way to do it. From the factory they were routed up onto the grille shell and attached to one of the same bolts that the radiator uses.
CSP is offline
post #6 of 25 Old 05-10-2013, 08:09 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Here's the factory setup that CSP is describing.
Matt
Matt1981CJ7 is online now
post #7 of 25 Old 05-10-2013, 08:31 AM
ki4cye
I have been thinking about running my vent tubes inside under the dash.
Sent from here to there using JeepForum
ki4cye is offline
post #8 of 25 Old 05-10-2013, 08:47 AM
firemanjim7
1983 CJ7
I'm not sure I would do this. Unless you like the smell of the axle oil.
firemanjim7 is offline
post #9 of 25 Old 05-10-2013, 09:20 AM
ki4cye
I thought about that too. The smell might get bad in summer
ki4cye is offline
post #10 of 25 Old 05-10-2013, 09:30 AM
firemanjim7
1983 CJ7
It might clash with our already gas cologne we are use to smelling like.
post #11 of 25 Old 05-10-2013, 09:46 AM
ki4cye
Very true
ki4cye is offline
post #12 of 25 Old 05-10-2013, 09:57 AM
M20Keeper
1982 CJ7
Mine has a strange...liquid wrench and oil smell...my wife hates it, maybe that's why I can't get her to ride in it, or touch me?
M20Keeper is offline
post #13 of 25 Old 05-11-2013, 05:42 AM
RDH
Even with my carb properly tuned per the Holley section on JunkyardGenius I get that cologne...adds to the experience I guess.
RDH is offline
post #14 of 25 Old 05-12-2013, 10:24 AM Thread Starter
CJBADASS
Axle Vent Tubing
Okay,
Quick question. Does anyone know what type of tubing that is for the differential ventilation? I want to replace both front and back (Dana 30 / 44). After 27 years mine is looking sort of old and ratty.
Regards,
Kevin C.
CJBADASS is offline
post #15 of 25 Old 05-12-2013, 10:34 AM
ki4cye
I have used rubber fuel line in the past without problems but dont remember what size it was
Sent from my DROID X2 using JeepForum
ki4cye is offline
