-   -   Front Axle Breather Question Dana 30 (http://www.jeepforum.com/forum/f8/front-axle-breather-question-dana-30-a-1521368/)
CJBADASS 05-10-2013 05:46 AM
Hello,
Can anyone show me a picture of how the front axle breather tube should be routed on a 1986 CJ7? Mine just goes up to the frame, and is just stuffed onto a hole in the frame. Lastly the breather cap in broken off.
Thanks,
Kevin C
RDH 05-10-2013 05:58 AM
Most of the time when I replace them, I run it as high up as I can and then loop it back down. Then again, I get into some pretty damaging things in the woods.
CJBADASS 05-10-2013 06:18 AM
Front Axle Breather Dana 30
Thanks for your response. How and where do you run it? Do you attach to the fire wall, just ty-wrap it? do you have any pics? I want to do it correctly, and deffinatly want to keep it away from mud, and water.
billybooster2 05-10-2013 06:32 AM
It attaches directly up to the RHS radiator and secures at the top thereof i believe
CSP 05-10-2013 07:23 AM
As long as it's up high enough to keep water out there really isn't a wrong or right way to do it. From the factory they were routed up onto the grille shell and attached to one of the same bolts that the radiator uses.
Matt1981CJ7 05-10-2013 08:09 AM
1 Attachment(s)
Here's the factory setup that CSP is describing.
Matt
ki4cye 05-10-2013 08:31 AM
81 Attachment(s)
I have been thinking about running my vent tubes inside under the dash.
Sent from here to there using JeepForum
firemanjim7 05-10-2013 08:47 AM
I'm not sure I would do this. Unless you like the smell of the axle oil.
ki4cye 05-10-2013 09:20 AM
81 Attachment(s)
I thought about that too. The smell might get bad in summer
firemanjim7 05-10-2013 09:30 AM
It might clash with our already gas cologne we are use to smelling like.
ki4cye 05-10-2013 09:46 AM
81 Attachment(s)
Very true
M20Keeper 05-10-2013 09:57 AM
Mine has a strange...liquid wrench and oil smell...my wife hates it, maybe that's why I can't get her to ride in it, or touch me?
RDH 05-11-2013 05:42 AM
Even with my carb properly tuned per the Holley section on JunkyardGenius I get that cologne...adds to the experience I guess. :laugh:
CJBADASS 05-12-2013 10:24 AM
Axle Vent Tubing
Okay,
Quick question. Does anyone know what type of tubing that is for the differential ventilation? I want to replace both front and back (Dana 30 / 44). After 27 years mine is looking sort of old and ratty.
Regards,
Kevin C.
ki4cye 05-12-2013 10:34 AM
81 Attachment(s)
I have used rubber fuel line in the past without problems but dont remember what size it was
Sent from my DROID X2 using JeepForum
The time now is 06:32 AM.
