Front axle bearings Dana 30 - JeepForum.com
post #1 of 6 Old 06-14-2003, 02:02 PM Thread Starter
tgc79cj5
My Jeep maintenance adventures continue.......
When I make a sharp turn, such as at an intersection, my front end now wants to take a hard dive to the right! I then have to hold the steering wheel to the left until I straighten back up. Otherwise everything is fine, drives great down the highway, no vibrations or erratic steering.
I raised the front end onto jackstands and checked for play in the front wheels. When I grab the tires at 12 and 6 and shake up and down there is a little play (I'm guessing maybe 3/4" play).
Is this too much play? Could this be causing the hard dive when turning? Do I need to replace the axle bearings? What else could be causing the hard diving?
Any help would be appreciated!
1979 CJ5
304 V8
T150 3 speed
Dana 30 Front
AMC 20 Rear
Dana 20 Xfer
BFG ATs 33x12.50
New Bestop Seats
tgc79cj5 is offline
post #2 of 6 Old 06-14-2003, 06:04 PM
fuzz401
1978 CJ7
3/4" is a lot in my book might want to pull the wheel and see were it is comming from look at the ball joints
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 6 Old 06-14-2003, 08:20 PM
hfjeff
hfjeff's Avatar
To my knowledge there should not be any play. The inner and outer bearings on the spindle are tappered so when the spindle nut is tightened, the hub gets sandwiched in between and rides on the bearings. If the ball joints are OK, pull the wheel off and manual locking hub and check the spindle nuts. You should not be able to spin them by hand. If they are tight I would pull the hub off and check the bearings.
hfjeff is offline
post #4 of 6 Old 06-15-2003, 12:00 AM
CSP
This is a very common occurence when the front axleshaft ujoints are worn out and binding up. It could be a sign of bad balljoints also. If it were me I'd start with the easiest and cheapest place first and pull the axleshafts. No effort should be required to move them.
CSP is offline
post #5 of 6 Old 06-15-2003, 09:36 AM Thread Starter
tgc79cj5
Thanks to everyone for the help! I will jack it back up and pull the wheels off and see what I can find.
This is a great forum! I really appreciate the advice!
I will post anything that I find.
Terry
1979 CJ5
304 V8
T150 3 speed
Dana 30 Front
AMC 20 Rear
Dana 20 Xfer
BFG ATs 33x12.50
New Bestop Seats
tgc79cj5 is offline
post #6 of 6 Old 06-29-2003, 05:07 PM Thread Starter
tgc79cj5
Well I finally got a chance to pull my front right hub to check the bearings............and found that the inside bearing was shot.
Replaced both bearings on the front right..........checked the left and found that the bearings are good, just repacked them and reinstalled hub making sure to torque everything correctly on both sides.
Thanks again for the advice and pointing me in the right direction!
Terry
1979 CJ5
304 V8
T150 3 speed
Dana 30 Front
AMC 20 Rear
Dana 20 Xfer
BFG ATs 33x12.50
New Bestop Seats
tgc79cj5 is offline
Dana 20 axle bearings? Decscorpion Jeep CJ Forum 21 06-16-2009 09:00 PM
DANA 44 Front Axle tlj0062000 Jeep CJ Forum 2 05-27-2009 09:23 AM
Dana 30 front axle Eric 76 cj Jeep CJ Forum 6 02-18-2008 04:51 PM
Best Dana 44 front axle dawgates Jeep CJ Forum 4 08-11-2005 04:44 PM
dana 30 front axle? js2 Jeep CJ Forum 9 10-03-2004 09:45 PM
