Fried something, but what? - JeepForum.com
post #1 of 8 Old 08-13-2010, 07:29 PM Thread Starter
dunnyCA
1979 CJ5
Can anyone help me figure out what may have gotten fried if anything.
Took my rig out for a spin yesterday, stopped for gas. Got back in and it wouldnt start. Turning the key does nothing, like a limp weiner. Lights etc on, they dont even dim or anything when I turn the key.
Thought maybe It was battery related at first since ive been having some problems with that, alternator gone bad i think, but a boost did nothing.
Once I got it towed home, the only visible sign of anything out of the ordinary was the solenoid to starter cable got a little melted from the header. Looks mostly like melted casing, cant see any actual wire.
If that's the source of my problem, would it just be the cable that needs to be replaced? Could the solenoid have been fried, as it doesnt seem to make a sound or anything when the key is turned. What about on the column itself, could a switch there or anything have been fried?
Thanks in advance for any ideas/suggestions.
dunny
dunnyCA is offline
post #2 of 8 Old 08-13-2010, 08:06 PM
brian613
1977 CJ5
use a multimeeter and see if your getting power out of the solenoid if you are then look at your grounds on the engine if your not then id replace the solenoide
brian613 is offline
post #3 of 8 Old 08-13-2010, 09:47 PM Thread Starter
dunnyCA
1979 CJ5
Hey Brian, thanks for the reply. Can you talk to me like I'm a 5yr old though. Learning as I go here. Where and how do I hook up the multimeter?
dunnyCA is offline
post #4 of 8 Old 08-14-2010, 09:48 AM
TBailey
1983 CJ7
I can just about garauntee its the selenoid.It sounds like it is stuck, when that happns it builds up heat in the cables and melts the insulation.
TBailey is offline
post #5 of 8 Old 08-14-2010, 10:13 AM Thread Starter
dunnyCA
1979 CJ5
Hoping it's that simple. Just picked up a new solenoid and replaced the starter wire + wrapped my header last night (still itching from the header wrap). Should have stuff back together this aft, will let you guys know how I make out.
Thanks for the input.
dunnyCA is offline
post #6 of 8 Old 08-14-2010, 08:30 PM Thread Starter
dunnyCA
1979 CJ5
im going to cry
Replaced starter cable and solenoid. Turn the key, and nothing, not a tick from anywhere. Check fuse too, replaced it for fun and still nothing.
None of the fusible links anywhere are burnt or anything. Is it possible that the coil got smoked somehow? What about something on the actual column?
dunnyCA is offline
post #7 of 8 Old 08-14-2010, 10:00 PM Thread Starter
dunnyCA
1979 CJ5
Haha! So after some googling, I thought it could be the ign switch on the column. After reading about it in my shop book, I thought maybe it's loose because something felt a little washy when turning the key. sure enough the while switch was moving with the rod. Held it in place and crank, almost woke up the kids.
Ahhh. So going for a cruise tomorrow.
dunnyCA is offline
post #8 of 8 Old 08-14-2010, 10:09 PM
brian613
1977 CJ5
cool glad you got it figured out...
o and owning a cj you need to learn to use a multimeeter for when (not if) you start having electrical issues.
brian613 is offline
cj5 , electrical , engine , jeep , starting
Fusebox fried? docbob Jeep CJ Forum 5 05-06-2009 07:49 AM
Is it fried SavSilvrCJ Jeep CJ Forum 2 11-16-2007 06:01 PM
Electronic ignition fried B'ham Jeeper Jeep CJ Forum 2 09-28-2007 02:53 PM
I think I fried my MSD... '83Laredo Jeep CJ Forum 1 05-12-2005 05:37 PM
Deep fried wires, need help! TheDuke276 Jeep CJ Forum 12 03-05-2005 10:19 PM
