FREE CJ emissions components - JeepForum.com
post #1 of 10 Old 02-03-2012, 11:50 PM Thread Starter
Fingergrindr
I have boxes and boxes of factory smog equipment for 1982 and up with the Carter BBD and emission control equipment. If anyone needs any of these parts to pass emissions just pay the shipping and I will be glad to send. Every vacuum valve, reservoirs, solenoids, diverters, molded hoses, computers, etc...I feel bad throwing it all away so if someone needs some help passing smog...temporarily or long term. If I kept the part it was in excellent working condition. I also have some stuff for the earlier model smog pump/air rail system.
Fingergrindr is offline
post #2 of 10 Old 02-04-2012, 12:34 AM
only in a jeep cj
Nice. I'll check tomorrow, but I think I'll try to get a downstream check valve and pipe from you. I was hoping the removed stuff from these older Jeeps didn't ALL go in the dumpster.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 10 Old 02-04-2012, 08:38 AM Thread Starter
Fingergrindr
I hate to say it but EVERY upstream/downstream tubes are completely rusted out.. But I have multiples of EVERYTHING else!!
post #4 of 10 Old 02-04-2012, 09:01 AM
GuacaTex
1981 CJ7
I'm in need of a Sol-Vac. That's the solenoid-vacuum positioner that bolts on the front of the BBD. It adjusts idle speed during warm up.
Got one of those?
GT
GuacaTex is offline
post #5 of 10 Old 02-04-2012, 10:27 AM
RenoF250
Do you have the EGR valve available?
RenoF250 is offline
post #6 of 10 Old 02-04-2012, 10:33 AM
waterdowg
PM Sent
waterdowg is offline
post #7 of 10 Old 02-04-2012, 01:47 PM
titomars
1981 CJ7
I am looking for the A.I.R. pump brackets on the 258. The flat bottom front pivot bracket which is part of the P/S brackets and the correct swing arm. I might need a couple of other things too. I have to look
titomars is offline
post #8 of 10 Old 02-04-2012, 02:52 PM
Blue83CJ7
1980 CJ7
Is that this thing? If so, you can have it for shipping...
1980 CJ7 - The Grenade
Blue83CJ7 is offline
post #9 of 10 Old 02-04-2012, 03:43 PM
Chuckles0227
1980 CJ5
Do you have a charcoal canister?
"If you sit when you pee, go with the square headlights..." - tawdr77
Chuckles0227 is offline
post #10 of 10 Old 02-04-2012, 04:37 PM
titomars
1981 CJ7
That's not it. Actually I am looking for either the one for AIR or Without AIR. here are some photos of both. It is the steel "brace" in front 2 bolt to the water pump and 2 bolts through the P/S pump.
titomars is offline
74 CJ5 heating components Mikes74CJ5 Jeep CJ Forum 6 10-14-2011 06:55 AM
ID these 3 components? spittoon Jeep CJ Forum 10 01-09-2010 08:25 PM
Evap System for Emissions Free 4.0L KUJeeper82 Jeep CJ Forum 4 01-02-2010 12:49 AM
78-86 Heater components in a 77 CJ5 Matusel3 Jeep CJ Forum 8 03-18-2008 06:57 AM
Free T-shirt Experiment... Yes FREE certifiablejeep Jeep CJ Forum 10 05-12-2005 04:42 AM
