Frame Rust On The Inside - JeepForum.com
post #1 of 2 Old 08-10-2002, 06:58 AM Thread Starter
Dtray332
Question Frame Rust On The Inside
DOES ANYONE KNOW IF YOU CAN MIX PAINT THINNER WITH POR 15, TO THIN IT OUT A LITTLE SO THAT IT CAN BE SPRAYED THROUGH A SMALL DIAMETER HOSE INSIDE OF A FRAME?
1986 Renegade CJ7, 258 straight 6, 4 inch Pro Comp lift, 33 inch Super Swampers (TSL Radial), Double Trail Master steering stabilizer, cool set of aircraft seat restraints.
Dtray332 is offline
post #2 of 2 Old 08-10-2002, 11:17 PM
Hippo393
Not sure, but is POR-15 oil based? The paint thinner directions say that it'd thin it via adding small amounts. Maybe try an 80/20 mixture for a small quantity to test it (I know POR-15 is expensive stuff).
I'm interested in how you're squirting in into the frame. Good luck and let us know what transpires.
-alan
Hippo393 is offline
Crap! Rust all on the backside and inside of water pump???? SparkyCJ7 Jeep CJ Forum 2 07-27-2009 08:49 PM
Rust Inside the Frame. Buy it? shok47 Jeep CJ Forum 12 06-10-2009 12:33 PM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 10:44 PM
Rust scale inside the frame skidplate77 Jeep CJ Forum 3 05-08-2008 09:50 PM
Mud or rust inside overflow tank? luckycheesehead Jeep CJ Forum 6 02-14-2008 05:30 PM
