Frame off build up Ideas - JeepForum.com
post #1 of 9 Old 08-03-2008, 03:32 PM Thread Starter
JFlanny11
Hey Guys,
Im looking to take my CJ off the road in a couple months, as soon as I can find a TJ as my new DD.
This thread is simply to get some ideas from suitable offroaders, as Im your weekend wheeler, doing trails you all would simply laugh at .
Im going to be doing my first frame off build up for a trail rig...not a rock crawler. What I would like to be able to accomplish with this is a trail rig I can haul a$$ in on the trail if I would like. Deal with rocks, Mud and logs ect. It doesnt need to be street legal but it would be nice.
Right now, Im running an AMC360, T176 , Dana 300, Amc 20 in the rear and Dana 35 in the front. Up on 33 x 12.50. So its stock with the exception on the Engine from at 88 Grand Waggy and the lift w/ tires.
This is going to be a long build up as far as time, I know what im doing to an extent but it is going to be a learning process for me. Moneys always an issue too but I want to take my time and do it right.
So, What id like from you guys is a direction to take to achieve my goals, Everything from Axles to armor. Specific products too direct bolt in swaps.......Anything will help
Thanks guys
J
J
JFlanny11 is offline
post #2 of 9 Old 08-03-2008, 03:48 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Shoot.. sounds like you have a pretty nice setup "as is".
I'd probably go for front/rear lockers and 4 to1 gears in the transfer case. Some skid plating, tough diff covers, alloy axles and fuel injection.. done.
BESRK is offline
post #3 of 9 Old 08-03-2008, 05:09 PM Thread Starter
JFlanny11
Besrk..... Whats the setup in your cj5
post #4 of 9 Old 08-04-2008, 06:26 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Trails + Haulin' A$$ + CJ = But I guess that all depends on your definition of Haulin' A$$... I've never seen a pre-runner CJ... But I guess anything is possible...
Nothing wrong with your powertrain. Except if it's really the D35 in the front (typo?). If you plan on Haulin' A$$ (and jumpin it), then you'll need to upgrade the front to a D44 or D60 and do the same with the rear. The FIRST decision you need to make is what size tires you will run. There are so many things that are affected by that ONE decision. If you want to stay with the 33" tires, you can probably get away with the stock 30/20 combo. With some mods. Start thinking bigger, than IMHO, go directly to the 60's or 60/14blt (or other HD combo). Remember: You said you wanted to 'do it right'.
Make that tire size decision, get back with us, and you'll get lots of real world experience. And lots of opinions.
This is going to be a long build up as far as time...
Do not start taking a running vehicle apart without a time frame. Ya gotta trust me on this. Too many projects end up like mine: 12 years in the making. Some never get done. What happens, is that some of the new parts you put on in 2008, are no longer new in 2012. Meaning you get to replace them again. Or the parts you removed in 2008 you can no longer find in 2010 because you've moved them 'somewhere'.
I'll give you one HUGE lifesaver: DIGITAL CAMERA. If you don't have one, get one. It is your 'memory', when 'Next Saturday' turns into six months away.
Yep. If it ends up like my project it'll be an expensive learning process. Again, it really does depend on what you want the Jeep to become. And what sort of 'finished' look you are trying to get. Obviously a trail 'beater' will not take the care/time to finish, as a 'show and go' Jeep will need during the build.
Nothing against you bro, but I've seen this statement posted so many times that it makes me either smile or laugh. Or both. I started with a $500 CJ5. You've got to add a couple more zero's to that figure to get to what I've dumped into this 'project'.
If money is/will be and issue, don't do a frame off rebuild. Again, it depends on what you want the vehicle to become. And there are so many variables and there are so many MAW's that you'll be running your CC up and draining your savings before you know it.
Like the term Haulin' A$$, it all depends on what your definition of 'do it right' is. Mine is not to remove good parts and replace them with more good parts two weeks later. If you aren't equiped, capable, or have the resources to tackle a build: It's gonna be expensive. The 'proffessionals' will take your money. And there are good pro's. And not so good pro's. All part of the 'learning experience'...
So, What id like from you guys is a direction to take to achieve my goals, Everything from Axles to armor. Specific products too direct bolt in swaps.......Anything will help...
Mild to Moderate Trail Street Legal CJ:
Stay with the drivetrain you have. 4" SUA lift, 1" BL. Run no more than a 35" tire, toss some 4.56 gears in the axles. Go ARB's (ya said ya wanted to 'do it right') or selectable in the front. At the very least on a CJ7 you can run a full Detroit in the rear and a soft locker in the front. Either install a hydroboost system or upgrade to a dual diaphram vacuum system. Oh, and dump the rear drums for a set of discs (they're better in mud). Toss in a 4:1 kit on the D300 (LoMax would be my preference) and properly twin stick it. 6 pt roll cage, harnesses, decent front bumper (with winch), decent rear bumper. Both with adaquate recovery points. Add some rock sliders, and corner protection (recess the tail lights). Consider installing an OBA system (you can use it to run the ARB's too).
I probably missed a few items (actually I know I did), but this is what you need to do before you turn a wrench and start taking things apart. Oh, and some advice about wrenchin' buddies: Don't let them work faster than you can 'keep an eye' on. 'cause they might be three states away when it comes time to re-assemble what they removed....
"In the end...It's all Hack."
HackFabrication is offline
post #5 of 9 Old 08-04-2008, 09:59 AM Thread Starter
JFlanny11
Thanks Hack,
First off Yea it was a typo on the front axle.
This is exactly what im am looking for, I know for sure I want to run 35's.
As for Haulin A$$, Im not talking 60 mph on the trail, Im talking 30-35 mph. Im not looking to jump the jeep but the front end coming off the ground without breaking anything would be nice.
Street legal, Is an issue I know cause Im going to go to flat fenders and chop the rear corners off, but id like that to be my only issue.
post #6 of 9 Old 08-04-2008, 12:44 PM
neatocj
1981 CJ5
Well,I used to be a prerunner guy. I had a 92 ford exploder with a custom suspension that I built and a custom solid axle swap from 2wd that I also did myself. It was a AWESOME vehicle for haulin down the dirt trails going 80, also it could take all tires off the ground type of big jumps, and playing in the mud it; was a awesome rig. But other than that pre-runner style lifts arent going to be all that good for rocks; logs are no problem.
Pre-runner is best for longer wheel base's I used to have a buddy that had a yj that was pre-runner. It was stupid, and he didnt just go the cheap way and just buy a set of larger lift springs for the front. He bought custom deaver springs that were set up to do pre-runner.
If your just gonna be going 30-35 you should just call up deaver springs and buy a set of springs that are a little bit softer, but will give you the same ride height. Thats up to you; its the pricy way to go, but its the smart way to go. Especially if your going to be doing a frame of resto/build.
Thats just my 2 cents. I don't think that I would do a full pre-runner style lift. But you can do whatever you feel like doing.
Your not pushing the limits of your jeep until your on your side, then something breaks and it's time to go home.
'70 Camaro - Almost Done
'81 Cj-5 - SOLD
'06 MegaCab Cummins- Great White
neatocj is offline
post #7 of 9 Old 08-04-2008, 04:14 PM
rckjeep
rckjeep's Avatar
1977 CJ7
I'm running 35's on dual D44's on an almost DD. The rear is stuffed with a Detriot 7 4.56's works well but I wish I would have had the $ for ARB's. Another rear axle to think about would be a Ford 9". They are easy to narrow but don't go to narrow. If you want to run 35's might as well build it to handle 37's that way you are covered in case you want to hammer down or run bigger tires later. I have a narrowed Chevy 3/4T 44 up front set to 58" WMS to WMS. Not a bad width for a CJ. It's 2" wider than widetrack. I see no reason to not swap out the axles for wider & stronger if you are going to go thru all the work of a frame off.
1977 CJ7 - built not bought
1995 ZJ - 5.2L daily driver
1953 Willys pickup - project truck
rckjeep is offline
post #8 of 9 Old 08-05-2008, 12:19 PM Thread Starter
JFlanny11
Thanks for the ideas rcjeep
post #9 of 9 Old 08-05-2008, 12:49 PM
neatocj
1981 CJ5
Well, I'm actually in the process of buying all the necessary components for my new suspension. I'm going to use a early model chevy dana 44 and a gm 12 bolt. I just got the jeep and I don't like it's stance it's way to narrow for me.
I am using the d44 and gm 12 bolt on purpose, because it will give me more to do in the future, such as dana 60's. I'm NOT going to be doing a frame off build cause I already have a good setup to go with 351W mean cam, ford t-18, dana 300. My only reall weak links are the stock dana 35 and the model 20 bohemoth's.
Like HackFabrication said, it's going to be LONG unless you buy all the parts in advance,but thats not always best. If your going to do a frame-off then I suppose you are going to re-do wiring, body work, paint,bushings and the essentials. If you do all the work to remove the jeep from the frame then you should be doing stuff like that.All that right there is not even all that cheap in it's self.
If you do a frame off you need to be sure you have the funds, time, patience, and the room to have bits and pieces of a completely dissasembled jeep laying all over the place. Its best just to go the whole 9 yards and re-do EVERYTHING, that is if you want one clean jeep.
If money is an issue maybe you should just do it one step at a time. First maybe you can get your drivetrain and suspension in tip-top shape with the goodies that you want in it. You don't want to get in too deep and then have to sell it. Research research research
'81 Cj-5 - SOLD
neatocj is offline
dented frame, any ideas? bmorrow Jeep CJ Forum 3 04-27-2009 01:58 PM
Jeep CJ7 build FRAME TIME ajstewart Jeep CJ Forum 0 09-18-2008 09:58 AM
Trail CJ build ?'s this is long but I like to get others ideas. texascj77 Jeep CJ Forum 13 09-20-2007 09:21 AM
Frame Coating Ideas Needed jayhawkclint Jeep CJ Forum 11 01-01-2007 03:45 PM
to build a CJ frame Dtray332 Jeep CJ Forum 14 01-11-2003 08:19 PM
