Frame Measurement Request - JeepForum.com
post #1 of 15 Old 04-19-2011, 08:25 AM Thread Starter
DT5150
1983 CJ7
hey guys, i need a favor. i need a measurement from a stock, unaltered cj7 widetrack frame. i need to know the distance between the front edge of the rear spring hanger, and the rear edge of the front spring hanger. both sides, just in case there's a difference. i need to know how far apart the front and rear spring hangers are.
my front end has been boogered up so bad by the PO, it isn't funny. so has the rear crossmember, or lack there of, but that's another story. my rear spring hangers are in the stock position, for sure. the rivet heads are still there so i know those are where they're supposed to be. but the fronts.. well who knows. the PO had done some half-arsed shackle reversal that i'm still trying to iron out. he got rid of the shackle reversal before he got rid of the jeep but didn't put things back together in the right places. thus, my front axle isn't sitting exactly square. i've got it close, but it's still off a little bit. so if i can get the distance between the two spring hangers, i can set my fronts exactly where they should be. thanks fellas
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #2 of 15 Old 04-19-2011, 08:48 AM
Jim1611
Jim1611's Avatar
The distance center to center on the hangers is 43 1/8", where the shackle bolt goes through each bushing. I just measured mine with a tape measure, not precise but it will get you close.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 15 Old 04-19-2011, 09:35 AM Thread Starter
DT5150
1983 CJ7
that's spring hanger to spring hanger?
DT5150 is offline
post #4 of 15 Old 04-19-2011, 12:16 PM
Jim1611
Jim1611's Avatar
No, I've got my own aftermarket spring hangers on my CJ so that measurement might not be the same as the factory hangers. The dimension I gave you is from the center of each mount where the spring attaches on the statioanary mount in the rear and where the bushing fits through the hanger in the front one.
Hope that helps.
My build thread
Jim1611 is offline
post #5 of 15 Old 04-19-2011, 02:33 PM Thread Starter
DT5150
1983 CJ7
thanks jim, i appreciate it, but i'd think it'd be best to reference my measurements from a frame with stock hangers. just to keep it simple.. i do appreciate the effort though.
DT5150 is offline
post #6 of 15 Old 04-19-2011, 06:45 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
wow just for clairity are you looking front to rear or between the rails? I'm going to be back under mine tomorrow and can put a tape on there for you.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #7 of 15 Old 04-20-2011, 08:15 AM Thread Starter
DT5150
1983 CJ7
yup, front to rear. my rear hangers are in the correct place, my fronts aren't. so since the rear hangers are correct, that the best place for me to measure from.
i need from edge of spring hanger, to edge of spring hanger (the forward edge of the rear spring hanger, to the back edge of the front spring hanger). thanks redman..
DT5150 is offline
post #8 of 15 Old 04-20-2011, 08:43 AM
mcmud
1983 CJ8
Hey DT,
I find both sides @ 44-1/16" between them.
mcmud is offline
post #9 of 15 Old 04-20-2011, 09:09 AM Thread Starter
DT5150
1983 CJ7
thanks T! is that edge to edge?
how ya been btw?
DT5150 is offline
post #10 of 15 Old 04-20-2011, 09:24 AM
mcmud
1983 CJ8
Aside from falling down the stairs last night then once I was able to stand up and make a way to the toilet only to pass out while taking a leak... pretty good. Thanks for asking.
Yeah and just for you I went all the way up the hill this morning with my crackling knees to lay on my sore back and measure the distance between the two at the point that each edge rest against the bottom of the frame rail.
Do you want me to waddle back up there for another spread point?
How you doin?
mcmud is offline
post #11 of 15 Old 04-20-2011, 09:37 AM Thread Starter
DT5150
1983 CJ7
no no.. that's perfect. thanks man.
sounds like you had a rough night. things here are good. busy as usual. headin to disney this saturday. it'll be nice to see some sun for a change.
DT5150 is offline
post #12 of 15 Old 04-20-2011, 09:53 AM
mcmud
1983 CJ8
Sounds good, pack sun screen and enjoy.
Oh... an if you see Goofy tell him mud said hello!
mcmud is offline
post #13 of 15 Old 04-20-2011, 10:20 AM Thread Starter
DT5150
1983 CJ7
will do
DT5150 is offline
post #14 of 15 Old 04-21-2011, 02:42 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
SOrry for being late back to the party.. Wife had a bad afternoon yesterday and spent it with her. Just to confirm i am right at 44". sorry for the late response...
post #15 of 15 Old 04-21-2011, 02:53 PM Thread Starter
DT5150
1983 CJ7
no worries bud. thanks for the confirmation. 44" it is...
DT5150 is offline
Need a frame measurement please... danholovic Jeep CJ Forum 7 02-05-2011 08:36 AM
measurement request petey156 Jeep CJ Forum 5 01-31-2011 08:39 PM
CJ5 Top Frame Pic request ideal_trucks Jeep CJ Forum 6 04-27-2010 11:28 AM
Frame measurement VACJ7 Jeep CJ Forum 3 06-14-2009 10:24 PM
Measurement Request: Spring hanger to shackle hanger DT5150 Jeep CJ Forum 5 05-08-2009 07:01 AM
