Frame compatibility - CJ-7 variants - JeepForum.com
post #1 of 6 Old 05-04-2016, 01:42 AM Thread Starter
Anith
I will be replacing the rusted out frame of my 1986 CJ-7. Is any frame of a CJ-7 - be it a Laredo, Renegade or a base variant - and any year, compatible?
Need urgent advice!
Cheers!
Imagine a world without Willys and CJs!
Anith is offline
post #2 of 6 Old 05-04-2016, 04:49 AM
sbcranger
Not if you are just looking to bolt everything together. The front shock towers are different between early and later 7 frames. , I don't recall if there are other differences but that's the easiest to spot Somebody correct me if I am wrong but I think 1980 and later will be the direct swap. They are the same between trim packages
sbcranger is offline
post #3 of 6 Old 05-04-2016, 07:30 AM
only in a jeep cj
While 82 to 86 will work just fine, 85 and 86 frames will be the only exact match.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 6 Old 05-04-2016, 10:23 AM
CSP
With the variations on 82-84 being??????
CSP is offline
post #5 of 6 Old 05-04-2016, 10:47 PM
only in a jeep cj
84 back used rear tub support bars spanning from the second to last set of body mounts to a rear floor channel. The last 2 years of the 7 did away with these and used a triangular support piece that was welded in this corner of the frame. It strengthened it and gave the body mount there double the thickness of steel to mount to.
For swapping this is not a problem other than the pre 85 folks will not be able to mount the support bars to the 85 and 86 frames and the 85/86 folks will see the frame is different in this area. With the OP in Italy, any CJ 7 frame in good shape will work. As mentioned above, the pre 82 will have different front shock towers (lower and fixed) vs the taller and bolt on. The earlier frames CAN be converted to the later shock towers but require cutting, drilling, and welding. Ive converted at least three and the trick is adding the crush tubes inside the frame.
While these little difference can easily be overcome by a seasoned Jeep guy or a fabricator, they may slow down or stop someone wanting to use their existing correct year parts on the non correct year frame. Examples include: second set of holes for the 20 gallon tank, Shock mounts on the widetrac axle vs the spring plate, rear tub support bars, inner fender clearance on the shock towers, etc, etc.
So when I suggest a certain year range, its taking all of this into consideration and making it easy for them. BUT, being in Italy, any rust free CJ 7 frame will have to work....
Ed
1975 CJ-6 1983 CJ-8
post #6 of 6 Old 05-09-2016, 09:50 AM
jeep_boy02
1980 CJ7
I've noticed the rear brake lines were routed differently too, not positive but probably starting with the wide tracs in 82. My 1980 NT has the rear line plumbed into the cross member on the front side of the rear hump in the frame(front side of rear axle), facing down. My 1986 WT has it plumbed at the rear of the hump on the same cross member that the front of the gas tank mounts to(rear side of rear axle) facing towards front.
I believe the shock tower difference is also 82-86 which coincides with the wide tracs.
jeep_boy02 is offline
