Frame/Body question from a newb - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Frame/Body question from a newb
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 09-16-2014, 11:36 AM   #1
butler18a
1979 CJ7
I need advice- Thanks in advance
I bought an ’86 CJ7 a couple weeks ago, and then a neighbor GAVE me a ’79 CJ(not sure if it is a 5 or a 7). Anyway- I am trying to figure out how much of the two are interchangeable? All Google searches just turn up forum discussions, no solid charts or lists of what is/is not interchangeable. I am really hoping the two bodies and frames are interchangeable.
Please advise.
butler18a is offline   Reply With Quote
Unread 09-16-2014, 12:23 PM   #2
1222
Make mine a Jeep!
1222's Avatar
Moved to CJ forum from JK section.
1222 is offline   Reply With Quote
Unread 09-16-2014, 01:30 PM   #3
Oddball73
1973 CJ5
First thing, if the 79 is a cj5 it will be around 10 inches shorter, and the door will have a hump, not the U shape of a cj7.
The 7 guys will have to help me out with this, the only major difference I know of is the frame change in the early 80's. They should be interchangeable but probably not without modification.
Oddball73 is offline   Reply With Quote
Unread 09-16-2014, 02:19 PM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
If the door openings look the same, you can swap both the tub and frame between them.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 09-16-2014, 02:39 PM   #5
Renegade82
Renegade82's Avatar
1982 CJ7
The axles changed in 82 on both so the front shock mount will be different. But a 5 and a 7 are two different bodies and two different frames, as was said.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote
Unread 09-17-2014, 06:50 AM   #6
butler18a
1979 CJ7
Thanks everyone. I work in Maryland and the Jeep is in Delaware. I will check it out tonight when I go to Delaware and see if the doors are the same.
Unread 09-18-2014, 06:16 AM   #7
butler18a
1979 CJ7
Here are the two jeeps. If I had to make a guess I would say the 79 (one with hard top) is CJ5... Any other opinions out there?
Unread 09-18-2014, 06:27 AM   #8
Kstein
Pretty sure that's a 7
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline   Reply With Quote
Unread 09-18-2014, 08:54 AM   #9
WindKnot
WindKnot's Avatar
1977 CJ7
Both Jeeps are CJ7s. The axles are not interchangeable. The '79 has a narrower wheel stance. If they are both 258CID inline sixes, many but not all parts are interchangeable.
Paved roads are just for getting you to the starting point!
Phoenix Rising- A Flame Off Restoration? http://www.jeepforum.com/forum/f8/ph...ation-1807257/
WindKnot is offline   Reply With Quote
Unread 09-18-2014, 10:11 AM   #10
butler18a
1979 CJ7
The '86 is a 258 inline, w/ manual tranny, the '79 has a 304 V8 automatic tranny. Ideally I would like to keep the 304 V8 in the '79 and add the manual tranny into the '79- is this possible?
Unread 09-18-2014, 10:18 AM   #11
jeepwhore
Hair puller xtraordinaire
jeepwhore's Avatar
It's possible, but depending on which model of manual trans the '86 has it may be a step backwards. The only manual trans offered in the last years of production with any kind of durability was the T176. The rest are classified as light duty transmissions and aren't worth the hassle of swapping, especially if you plan on running larger than stock tires with the stock geared differentials.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote
