fram - JeepForum.com
post #1 of 3 Old 06-12-2002, 11:39 AM Thread Starter
beachcruzr
Unhappy fram
any ways to repair a craked frame?
please inform me
82 cj7
fiberglass body
4" skyjacker lift, 2" body lift
moser heavy duty one peice rear end
33" bfg muddies
currently undergoing a frame and engine swap.
beachcruzr is offline
post #2 of 3 Old 06-12-2002, 02:50 PM
Boggy Bottom
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by beachcruzr:
<strong>any ways to repair a craked frame?
please inform me</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Here... Sign this form, because I am formerly an informer, but I never wore formal attire. For your information, this is merely a formality.
&lt;grin&gt;
Here is the quick and dirty version:
1. Remove enough bolts from your body to jack it up a couple inches.
2. Jack up, or otherwise manipulate your cracked frame into it's original alignment/configuration.
3. Make quarter-inch steel plates to match the area you wish to repair. Cut out some sections inside the plate area, so that the plate itself can become a stressed part of the frame... DON'T JUST WELD AROUND THE EDGES!!! That would be like repairing your broken baseball bat by using a soda can and a hose clamp.
4. Weld on the plates one at a time. If you are a welder, used DEEP penetration to get the strongest bond possible.
5. Paint it when it cools.
Now here is the sermon:
If your frame is cracked in one spot. Chances are your whole frame needs attention. Do a frame-resto. You will be glad you did. No, I know what you are thinking. You can do a fairly clean restoration job to your frame, and not have to remove the engine. It's easier, but not necessary.
In the end, there are many different ways to start and finish a project like a cracked frame. Frankly, if you aren't a welder, just take it to a welding shop. Most likely they will be able to help you and provide better workmanship than a scabbed-up plate job from a local-yokel garage. Course, you're gonna pay for it. Better to pay for it and get it done right instead of finding out on the trail that you got poked real hard by the good-ol-boys.
Good luck and hope this helps!
Ol' Boggy Bottom
'83 & '84CJs, '51, '53, and '57 Willys Pickups
Boggy Bottom is offline
post #3 of 3 Old 06-13-2002, 07:15 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Thumbs up
Good advice!
4wheeler4CJ is offline
Top Cowl widow fram rust help (morris?) Bkvbob Jeep CJ Forum 1 11-05-2009 08:25 AM
304 engine fram-side mounts to 360... vladrulli Jeep CJ Forum 2 07-21-2006 06:07 PM
Fram filter question kicknjeep Jeep CJ Forum 6 02-22-2003 08:02 PM
