Four wheel drive problem? - JeepForum.com
post #1 of 5 Old 10-30-2010, 03:44 PM Thread Starter
RedHotChiliDog
I have a 1978 CJ-5 with a 304 V-8 and a 3 speed manual transmission. When I shift the transfer case into four wheel drive high everything seems to work fine and the Jeep will spin the front tires in the*dirt or snow. When I shift the transfer case into four wheel drive low you can feel the gear*reduction in the transmission and the Jeep does become geared down with more torque. The problem is only the rear tires will spin and the Jeep does not appear to be in four wheel drive. Is this problem most likely a shift linkage problem or is there some type of problem in the transfer case which is not allowing it to go into four wheel drive? Thanks.
RedHotChiliDog is offline
post #2 of 5 Old 10-30-2010, 04:21 PM
zillla
1930 VJ
My 75 will go into a 2-low mode if I don't get the lever down all the way to the floor..
zillla is offline
post #3 of 5 Old 10-30-2010, 04:51 PM
turnabout
1974 CJ5
Sloppy (worn) or partially disconnected linkage can cause this problem. It is amazing how much wear and tear occurs over the years with the transfer case shifter bouncing around during normal driving, much less off road terrain.
The two best off-road vehicles in the world -- the Jeep CJ and rental cars.
turnabout is offline
post #4 of 5 Old 10-30-2010, 06:03 PM
panman
i agree with turnabout.and i would sugest a twin stick setup since you'll have to pull the stick out to replace bushings and such. besides,from what i hear the option of full selectability is worth while.
panman is offline
post #5 of 5 Old 11-01-2010, 09:09 AM Thread Starter
RedHotChiliDog
You were right! it just got so stiff I didn't think it could go any lower! Thanks!
Using four wheel drive Nelson Jeep CJ Forum 32 08-25-2010 12:03 AM
6 wheel drive CJ? 243 Jeep CJ Forum 9 05-07-2010 11:55 PM
1978 cj7 problem going int 4 wheel drive extremecj7 Jeep CJ Forum 7 12-24-2008 10:14 PM
Jeep Cj7 4 wheel drive light problem funinfuneral Jeep CJ Forum 7 07-20-2007 01:30 PM
no 4-wheel drive bdruff Jeep CJ Forum 15 01-24-2007 07:29 AM
