Found oil leak, what do I do now? - JeepForum.com
post #1 of 25 Old 01-13-2010, 08:35 AM Thread Starter
MSBXCJ
1982 CJ7
Im almost positive oil leak is coming from rear main seal. It is seaping out of the bottom of transmission where it meets the back and bottom of oil pan. Isnt that where the rear main seal is? If I am right, after I buy a new seal, what do I do then? Is this a pain in the butt to fix? Thanks, I dont know what I am doing.....
MSBXCJ is offline
post #2 of 25 Old 01-13-2010, 08:38 AM
rrtex1
1981 CJ7
Can I bring mine over and do them at the same time? I think I have the same problem.
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #3 of 25 Old 01-13-2010, 08:39 AM
fredrok
Never seen a 258 that didn't seep. Just marking it's territory.
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #4 of 25 Old 01-13-2010, 08:48 AM Thread Starter
MSBXCJ
1982 CJ7
rrtex1, you are in round rock? cool. if i buy the seals will u fix them? hehe
MSBXCJ is offline
post #5 of 25 Old 01-13-2010, 08:49 AM Thread Starter
MSBXCJ
1982 CJ7
Is this something important i should worry about? its kinda messy...
MSBXCJ is offline
post #6 of 25 Old 01-13-2010, 08:59 AM Thread Starter
MSBXCJ
1982 CJ7
it is coming from here...
MSBXCJ is offline
post #7 of 25 Old 01-13-2010, 09:00 AM Thread Starter
MSBXCJ
1982 CJ7
MSBXCJ is offline
post #8 of 25 Old 01-13-2010, 09:05 AM
Twistedper
1979 CJ7
Mine did too. I just happened to have a motor that doesn't leak and now am in the process of finishing the swap. It doesn't help much that it is COLD here. It is one of those things where you have to weigh, amount of work to fix and how much does it bother you. I know I will get the opportunity to fix the motor that I pulled but until it warms up I haven't done it yet. Anyway good luck.
79 CJ 7, 258 I6 TR, T 150, Dana 20, Dana 30, AMC 20 and 31" Uniroyal A/T Tires
Twistedper is offline
post #9 of 25 Old 01-13-2010, 09:11 AM
Mike Romain
Before attacking a rear main, I highly recommend you run the engine for a few minutes to warm it up and then take a clean rag and rub the engine head around the back side below the valve cover. If you find oil there, you have found the leak likely, well 'a' 'valve cover' leak that for sure imitates a rear main seal leak perfectly.
Mike
Last edited by Mike Romain; 01-13-2010 at 09:20 AM. Reason: forgot a couple words.
Mike Romain is offline
post #10 of 25 Old 01-13-2010, 09:17 AM Thread Starter
MSBXCJ
1982 CJ7
Thanks Mike!! If I find a leak there, is that the valve cover leaking?
MSBXCJ is offline
post #11 of 25 Old 01-13-2010, 09:20 AM
Mike Romain
Oh yes, and the engine tilts back so it runs right down to the bottom.
Mike
post #12 of 25 Old 01-13-2010, 09:24 AM Thread Starter
MSBXCJ
1982 CJ7
i hope it is just the VC....
MSBXCJ is offline
post #13 of 25 Old 01-13-2010, 09:29 AM
DT5150
1983 CJ7
if you find it is your rms leaking, here's an excellent step-by-step with pics write-up on how to do it. it's not an overly difficult job, but it is a pita. pretty messy and time consuming but doable if you're somewhat mechanically inclined.
Rear Main Seal Service and Replacement
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #14 of 25 Old 01-13-2010, 09:51 AM
thord
Add enough oil to replace the missing oil!!!
Congrats you now have a CJ!
thord is offline
post #15 of 25 Old 01-13-2010, 11:27 AM
MoC
Did mine a few months back. As you will see when you read the step by step instructions will have to remove a motor mount. Even with the motor mount out is was still a little tricky getting it in to place without knocking a gasket loose. Having a extra set of hands around really made getting the oil pan back in to place easier.
MoC is offline
Found a CJ 10 Balvar24 Jeep CJ Forum 12 12-15-2009 07:56 PM
So I found this 360... h1driver Jeep CJ Forum 5 10-30-2008 05:19 PM
Found a CJ WVMIKEsTJ Jeep CJ Forum 1 09-16-2005 12:35 PM
Vacuum Leak/Gas Leak ravinhuxley Jeep CJ Forum 2 03-09-2005 08:18 AM
What am i getting into? Found - CJ5 rhurley Jeep CJ Forum 2 09-06-2004 04:49 PM
