found a great offer on a first jeep HELP - JeepForum.com
post #1 of 13 Old 03-12-2003, 07:56 PM Thread Starter
kingkong827
how are you guys doing. I am considering a CJ. i just went and looked at a 84 cj7 5sp in good shape. its got a bunch of goodies in it. new motor new front end u-joints, has hard top, soft top, rough country 4" lift, 32" dueller mts new floors (welds look good)
It was dark and had minimul light so i am going again on friday. What are things to look for as far as rust, motor, tranny problems.
what ever comes to mind let me know i am in no rush until i find the one. I used to own a toy 85 runner soild front body lift and 32s. i sunk it in the conneticut river so i am looking for a new off roader.
kingkong827 is offline
post #2 of 13 Old 03-12-2003, 09:07 PM
CJ junky
Take it for a good ride , especially on the highway and go through all the gears. Listen for transmisson bearing noise and any other noise. Check the frame good, look for rot at / around the front and rear spring perchs. Make sure the oil pressure is at least 35psi @2000rpm and the engine warm. Make sure the body mounts are solid and intact. I'm sure there are other things but these are the basics. Good luck and happy JEEPIN.
CJ junky is offline
post #3 of 13 Old 03-12-2003, 09:55 PM
CJ7Jeff
35 psi at 2000rpm? I better get rid of mine then. It will only do that when it is stone cold. When it is warm I get about 40psi at 2800rpm. A good rule of thumb that I always follow is 10 psi for every 1000rpm.
I would check everything stated above and look at the floors and body mounts to make sure they aren't rusted out/off. Depends on how much work you want to put into it really.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
post #4 of 13 Old 03-12-2003, 11:58 PM Thread Starter
kingkong827
how would i go about test the oil pressure? How is th e rough country lift
post #5 of 13 Old 03-13-2003, 01:08 AM
Jeep Daddy
Jeep Daddy's Avatar
Rough Country's are a little stiff and don't articulate as well as others, but it's not bad. Let us know what else it has. Ask the guy if the diffs are stock or if they are locked or if the gearing has been changed. Look under the dash and see if the wiring is in fair shape. Does it have a winch? stock bumpers? spare tire? jack? any storage boxes that are security tight? stereo? CB? How's the paint?
Most important is rust or cancer. And what price is the guy asking?
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #6 of 13 Old 03-13-2003, 01:41 AM
DaRaidz
Check out the 4x4
Make sure you shift into 4 lo and 4 hi and drive a short distance. Should not be any abnormal noises etc. Check the clutch for where it engages and how it feels etc. Good luck
'86 CJ7 I-6, 5 speed, 33 Pro Comp, BDS lift, CD, Hardtop and Doors, 4X Dr. Rockers, 4.88 gears, ARB Air Lockers front and rear, Dana 44 rear, 63K original miles...very sweet rig.
DaRaidz is offline
post #7 of 13 Old 03-13-2003, 02:03 AM
scottahicks
scottahicks's Avatar
and for heaven sakes tell us what he wants for the thing so that we can give you an idea of fair market value
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline
post #8 of 13 Old 03-13-2003, 09:34 AM Thread Starter
kingkong827
he is asking 4500 obo. the diffs are open. and he says he has 3500 in recent recipits every thing else is stock paint is ok and it has diamond plate
i asked if it had rust under the diamond plate and he told me there was surface but no rot. how would i go about taking that off to take a look at that.
post #9 of 13 Old 03-13-2003, 10:32 AM
Jeep Daddy
Jeep Daddy's Avatar
Where's the diamond plate? around the rear corners of the tub? Just take a flashlight and look up behind the tub. $4500 seems kind of steep for what you are describing. I'd offer $3500 and see what he says. That's what I paid and mine has no body rot.
He really doesn't have a lot tied up in mods and that's what's going to cost you after you buy it. The lift kit is a cheap one. I don't know how the tires are but more than likely they are not what you want so you'd probably be changing rims and tires.
IF this jeep were in such good shape that you didn't need to fix a single thing, it may be worth that kind of money. I did have to fix a lot of little things, and still have more to fix. Fuel gauge, temp gauge, seat, door locks, door seals, window crank, top snaps, rear brakes completely shot, motor, tranny, t-case all leaked like a sieve, turn signals, brake lights, radio, etc. You get the picture.
In the end, it's whatever you think it's worth to you.
Good luck.
post #10 of 13 Old 03-15-2003, 05:19 PM Thread Starter
kingkong827
thanks for the info
post #11 of 13 Old 03-16-2003, 02:14 AM
scottahicks
Personaly at least in my area here in Oregon, and in Georgia where I just came from,, $4500. is a lot for that jeep, you could buy a jeep set up the same as the one your describing from a used car dealership here and we all know there over priced,,, 3000-3500 would be a better price if you can get him down on it,, and as for the recipts... WHO CARES!!!!! its nice to see recipts but we all know you NEVR EVER get out of a 4x4 what you put into it. there is a cj-7 here in town that is ABSOLOUTLY IMACULATE! I have personaly seen the 21,000 dollars in recipts and thay all match up,, this thing is the apitomy of a full featured trail and street rig,, i mean its got everything and its selling on comission at a car dealership for 9,500 and someone would buy it for that im shure,, hell i would if i could afford it but the reality of it is everyone puts money into their jeep to make it the way they want it and not to get a higher resale value and if they do there INSANE!!!!!! just my thoughts
post #12 of 13 Old 03-16-2003, 10:08 AM
Jeep Daddy
Jeep Daddy's Avatar
I agree with scottahicks. I know a guy that's selling a 95 YJ with a 4 banger for $5000. It's got a little over 80k miles on it and everything is perfect and it's mostly stock. I believe it's about $1000 under KBB or more. You can do better.
post #13 of 13 Old 03-21-2003, 04:03 AM
Sandman74
3500 in reciepts? What a quitter! I bet most of us have 3 times that in reciepts and have a wish list 3 times longer than that. This poor guy didnt realize that Jeeps are never finished... 3500, God I wish I only had 3500 in reciepts. If you do buy, be realistic about what you have and what you will have to spend in the future. As you know spending the kind of money we do is hard to rationalize to some people, but for the love of god, at the end of the day you are driving a Jeep and that s all anyone really needs.
peace
sandman74
Youth and talent is no replacement for age and treachery.
Sandman74 is offline
Great fall day Jeep Weather hold24 Jeep CJ Forum 5 10-29-2009 07:59 AM
Can someone identify the suspension on my Jeep. Offer opinions on it. Stacydmcc Jeep CJ Forum 11 07-27-2009 09:01 AM
Great site for Jeep lovers Curt Reinhardt Jeep CJ Forum 4 02-17-2009 12:00 PM
Jeep Turning Radius (Jeep Turns To The LEFT Great, Not So Much To The RIGHT) Military Jeeper Jeep CJ Forum 8 02-27-2008 11:08 AM
Great Jeep weather tomorrow Mudbuggy Jeep CJ Forum 1 04-30-2006 08:16 PM
