Found this on Craigslist...is it a good deal? - JeepForum.com
post #1 of 13 Old 04-16-2012, 07:23 PM Thread Starter
thartleystj
Found this axle on my local Craigslist. Is it a good deal? Also will this fit under a later model cj5?
Thanks,
The CJ Noob
1999 Jeep Wrangler TJ
4" Lift Kit, 20" XD Rockstars w/32" Nitto Terra Grapplers
thartleystj is offline
post #2 of 13 Old 04-16-2012, 07:25 PM Thread Starter
thartleystj
http://springfield.craigslist.org/pts/2898717758.html
Sorry forgot the link
post #3 of 13 Old 04-16-2012, 07:32 PM
inovermyhead2
I would snatch it up for that price. You can probably get it for $75
1983 CJ7
350ci Chevy
SM465 Trans
Rancho 2 1/2" lift
Confer Engineering Shackles
32x11.50x15 BFG All Terrains
whoever invented Torx bolts should be shot in the face, burned then pissed on - saskcj7
inovermyhead2 is offline
post #4 of 13 Old 04-16-2012, 07:36 PM
Trapshooter
Pull the diff cover and confirm there is something in there. Inspect the ring and pinion for damage. I would also measure to confirm it is a wide track.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #5 of 13 Old 04-16-2012, 07:37 PM Thread Starter
thartleystj
Do you know if it will fit under a 76-83 cj5? Planning a future build
post #6 of 13 Old 04-16-2012, 07:39 PM Thread Starter
thartleystj
How wide should it be? Sorry I really don't know much about CJ stuff...I'm trying to plan a cj5 build assuming this will fit under a 76-83 cj5...for a future build
post #7 of 13 Old 04-16-2012, 07:49 PM
Trapshooter
The Dana 30 wide track was 56" wheel to wheel.
The Dana 30 narrow track was 53" wheel to wheel.
Spring pads are at 28" for both.
Yes, the axle will fit under a CJ5 built in 76 to 83, wide track axles first appeared is CJs in 1982.
Good Luck..........
My 401 build:
post #8 of 13 Old 04-16-2012, 08:02 PM Thread Starter
thartleystj
Good Luck..........
Thanks so much for the help!
post #9 of 13 Old 04-16-2012, 08:50 PM Thread Starter
thartleystj
Picked it up for $80! My first part for my future CJ5!
post #10 of 13 Old 04-16-2012, 08:56 PM
BeatCJ
1981 CJ5
I have an '83 Widetrack in my CJ-5. If you go with any lift, you will need longer brake lines. I used Chevy 1/2 ton pickup lines from NAPA. Other than that, simple swap.
There are some things you will learn while holding a cat by the tail that can be learned no other way...
BeatCJ is offline
post #11 of 13 Old 04-16-2012, 09:04 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
not too bad, i can tell its a WT from the pic. i gave one away for free last month complete with 3.54's, too bad your not closer, coulda saved you $80
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #12 of 13 Old 04-16-2012, 09:06 PM
mopar346
The disc set up is probably worth that, you did fine.
Careful your character's showing
mopar346 is offline
post #13 of 13 Old 04-16-2012, 09:38 PM Thread Starter
thartleystj
Thanks guys! I'm just ready to start my build but I guess I need a CJ5 first...kinda important! I'm looking for something cheap that really hasn't had anything done to it. I don't even care if it runs! I just wanna do a complete build myself
Good deal on Craigslist in Pittsburgh area 4lowherewego Jeep CJ Forum 0 01-29-2011 08:58 PM
Looks like a good Craigslist Deal if anyone interested rrtex1 Jeep CJ Forum 1 01-05-2011 03:29 PM
CJ7 on craigslist.. almost too good of a deal to be true? WILLY348 Jeep CJ Forum 3 07-25-2009 06:15 PM
Good deal on a CJ frame (Craigslist find) Seether Jeep CJ Forum 0 06-24-2007 05:19 PM
Found the Jeep I want, good deal or no? durdenclub Jeep CJ Forum 5 07-12-2004 11:53 PM
