Forum Newbie - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Forum Newbie
Dan's Old as Dirt Birthday Sale!GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Yukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 05-25-2014, 11:03 AM   #1
Savage1966
1983 CJ7
Forum Newbie
Hello, new to the forum. I've previously owned 2 jeeps, one was a YJ, the other a TJ. Neither of them had problems or issues. That was 10 years ago. Last week I purchased my first CJ7. This one has a few bugs to work out, so I'll have lots of questions. I'm hoping to learn a lot from you veteran CJ7 owners.
Savage1966 is offline   Reply With Quote
Unread 05-25-2014, 11:50 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Welcome to the forum, the CJ looks in nice shape.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 05-25-2014, 12:26 PM   #3
firegod33
1977 CJ5
Welcome aboard. Good looking CJ!
Earth first... We'll Jeep the other planets later.
firegod33 is offline   Reply With Quote
Unread 05-25-2014, 03:07 PM   #4
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Welcome to the CJ world! Put some large sheets of cardboard under her to see what's leaking.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote
Unread 05-25-2014, 06:08 PM   #5
Renegade82
Renegade82's Avatar
1982 CJ7
Welcome to the forum and the world of "the real Jeep".
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote
Unread 05-25-2014, 08:58 PM   #6
Savage1966
1983 CJ7
Thanks. Glad to be here. I've found a few of the leaks. The valve cover was leaking, fixed that one already. Once I got all the oil off of it I found the distributor gasket and power steering pump leaking. I'll order those tomorrow. Found a set of tires and wheels today and got them put on. Looks like I'll need to put a lift on it. They are 35" tires, will a 2.5" lift work or do I need to go 4"? Here is a pic.
Unread 05-25-2014, 09:42 PM   #7
firegod33
1977 CJ5
I would go 4". 2.5 is just a tad too low for my 33s
Unread 05-25-2014, 11:40 PM   #8
Renegade82
Renegade82's Avatar
1982 CJ7
Go 4" for sure. That Jeep ought to look pretty sharp lifted up off those 35's.
Unread 05-26-2014, 12:46 AM   #9
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Personally, I liked it much better with the smaller tires and chrome wheels, but it's your rig.
Be advised, a 4" lift requires more than just different springs. If done correctly, the steering, driveline, brake lines, and perhaps the e-brake will all need to be modified.
Also, do you have the gearing for those 35"s? You'll need 4.10s, or higher, to turn that much rubber.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 05-26-2014, 01:32 AM   #10
BagusJeep
1981 CJ7
Yipes, those 35s remind me of Gladys when I first got her. The 35s looked fantastic, but slowed her to the point of snail like movement and I have 4.88:1 gears and a T18 with a granny low first. I have my CJs on 31s and stock springs, you rarely find something on a trail which cannot be driven over/around. Gladys now rests on 33" tyres just to lower the gearing on the trail, I rarely load it to anything like 7000lbs and ultra low gears are not a huge need.
You will need 4" of lift and changes to steeing, probably driveshafts and brakes to make it handle well. Also the 258 may need upgrading a little and the axles regearing so the engine does not bog. I also liked the smaller tyres and rims, but that is just me as a 31" fan and it is your Jeep!!!
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote
Unread 05-26-2014, 06:06 AM   #11
steve1973
1973 CJ5
Those smaller tire sans chrome spokes were much cleaner looking with the CJ lines IMO. It might've wise to let it all soak in before making any drastic changes. Get it safe and reliable, and drive it for a month or two stockish
But is your Jeep, only you can decide.
steve1973 is offline   Reply With Quote
Unread 05-26-2014, 06:15 AM   #12
Ken4444
Corripe Cervisiam
Ken4444's Avatar
x2. But I'm more of a purist.
Unread 05-26-2014, 06:16 AM   #13
jp360cj
1977 CJ7
If you plan to wheel a CJ with 35s you will need to trim the wheel wells or they will rub
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is online now   Reply With Quote
Unread 05-26-2014, 06:41 AM   #14
Savage1966
1983 CJ7
Thanks for all the feedback. I saw the 35's and jumped on them. However, I really don't want to have to change, driveline, steering, and brake lines. Perhaps 33's would have been a better choice. If I go will 33's will I be able to get by with a 2.5" lift and nothing else?
Unread 05-26-2014, 06:52 AM   #15
Mike Romain
Yes, I have a 2.5" spring lift and the heavier duty YJ shackles which add another 1/2" and clear my 33's no problem.
Mike
