Ford t19 & 302/351 w/ Dana 300 - Page 2 - JeepForum.com
post #16 of 24 Old 09-30-2011, 11:13 PM
Coiz
1979 CJ7
Originally Posted by ctappan94 View Post
Not to be an idiot...but whats a synchronized transmission mean
All manual transmissions have synchronizers to help the moving components come to the same speeds as you shift through the gears. As you accelerate and shift through the gears, the input shaft is raising and lowering in rpms with the engine while the output shaft matches the axles and continues to get faster as you accelerate through the gears. The synchronizers and blocking rings are what helps those components come to the same speed while making the shifts.
What Stumpbumper is referring to are the transmissions with the 6+:1 granny first gears where they are not synchronized. What this basically means is that you must be stopped to shift into the granny 1st gear, all other gears are synchronized so the shifts can be made while moving.
As Cutlass and CSP mentioned, all of the 3 and 4 speed trans have the same 1:1 top gear so there will be no difference in highway driving. So when your choosing between 3 and 4 speed transmissions, you are basically choosing the overall strength and which 1st gear you are looking for. The only time I would pick a T19 is if I were running over sized tires with too high an axle ratio and was mainly being driven on the street. In that instance the 4.03:1 first would be the most usable for starting on the street. The 5.11:1 would be too short and the 6.32:1 is a granny. So either you're looking for a granny first gear or your not.
I traded out of a T18 to a NP435 because it was a direct bolt on to the Ford engine and has a steeper 6.68:1 granny and steeper 3.34:1 2nd gear as compared to the 6.32:1 and 3.09:1 2nd gear of the T18/19. The granny gives me a 67:1 final crawl in 4Low and the 3:34:1 2nd gear is 8% lower than the T18/19 which is better for starting on the street. 2nd gear in 4Low has plenty of nuts with the 302.
Hell, second gear in 2High has plenty of nuts.
Mike
Coiz is offline
post #17 of 24 Old 09-30-2011, 11:21 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i too, LOVE my NP435/d300 combo.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #18 of 24 Old 10-01-2011, 07:43 AM Thread Starter
ctappan94
1983 CJ7
Alright so with the T18/19 on the 302/351 would need a special adapter but the np435 is a direct bolt on? Ok guys thanks so much Ill try to find one
ctappan94 is offline
post #19 of 24 Old 10-01-2011, 07:57 AM
Stumpbumper
T18 T19 and 435 are all brothers. They all need the adapter! He already had a T18 so he was able to use what he had!
The T19 in the 4-1 and 5-1 synchro first allows you to down shift to first while moving. I had a T19 I put in a trail rig (74 cj5) and loved the ability to grab a lower gear while moving down the trail!
I trail road and wasn't rock crawling, so any lower first would have been un-usable for me but everyone needs to set the jeep up the best for them!
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #20 of 24 Old 10-01-2011, 10:44 AM
Coiz
1979 CJ7
As stated, the T18/19 and NP435 all bolt directly to the Ford engines. The adapter you will need will be for the transmission to transfercase.
Mike
Coiz is offline
post #21 of 24 Old 10-04-2011, 07:13 AM
CSP
To be more specific, the T18/19 you would find originally in a Ford will bolt directly to Ford engines via Ford bellhousings.
A Jeep T18 will not directly bolt to a Ford engine via a Ford bellhousing. The input shaft will be too long.
CSP is offline
post #22 of 24 Old 10-04-2011, 07:15 AM
Jim1611
Jim1611's Avatar
Hey CSP isn't there a thread on here where someone modified the input shaft on a Jeep tranny to work with the Ford?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #23 of 24 Old 10-05-2011, 06:59 AM
CSP
None that I've ever seen, but that doesn't mean one doesn't exist. The idea is entirely possible, but it would be easier and probably cheaper just to swap a Ford T18 input shaft into a Jeep T18.
CSP is offline
post #24 of 24 Old 10-05-2011, 07:22 AM
duckbone
Actually the splined part of the two shafts are the same it's just that the pilot bearing nose of the jeep shaft is one inch longer. It may all fit in the crank if you use the right pilot bearing or you could maybe just cut one inch off the nose of the jeep shaft. I just pulled the 351-t18 set up out of my jeep to swap a 401 in. I have a lakewood bellhousing and the Advance Adapters motor mounts for it for sale but the shipping would be cost prohibitive as they weigh at least 50lbs.
duckbone is offline
Dana 30 ->ford 9" or Dana 44 Front Axle Swap smoothop Jeep CJ Forum 9 09-18-2011 09:28 AM
ford 2wd t-19 to dana 300/20 petey156 Jeep CJ Forum 1 06-01-2011 07:52 AM
Ford Dana 60 rearend 77cj5BEAST Jeep CJ Forum 9 02-23-2007 02:19 PM
Ford T-18 to a Dana 30 ncdeerejeep Jeep CJ Forum 8 11-28-2006 07:22 PM
Best Axle out there??? (Ford 9"/ Dana 44/AMC 20/OTHER) jeepcj7 Jeep CJ Forum 4 03-21-2003 11:54 PM
