Ford t19 & 302/351 w/ Dana 300 - JeepForum.com
post #1 of 24 Old 09-29-2011, 06:35 PM Thread Starter
ctappan94
1983 CJ7
Dana 70 front, dana 80 Rear. Will this set up work ok or will I need to change some things around? thx
ctappan94 is offline
post #2 of 24 Old 09-29-2011, 07:00 PM Thread Starter
ctappan94
1983 CJ7
anyone?
post #3 of 24 Old 09-29-2011, 07:55 PM
Coiz
1979 CJ7
It should work fine, you just need the adapter from the T19 to the D300. If you're really going with the D70 and D80 combo, I would go with the 351 for the added torque. I've got the 302/NP435/D300 and its got plenty of pep but I'm not running monster axles or tires.
What axle ratio and tire size are you looking at getting?
Mike
Coiz is offline
post #4 of 24 Old 09-29-2011, 07:59 PM
Jim1611
Jim1611's Avatar
One thing you're going to find with that size front axle is that the engine is going to have to sit higher so that you have room between the axle housing and oil pan. Any reason you're using the T-19 and not the T-18?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #5 of 24 Old 09-29-2011, 08:02 PM
Coiz
1979 CJ7
I was going to ask the same thing but assumed he already had one.
Mike
Coiz is offline
post #6 of 24 Old 09-29-2011, 08:43 PM Thread Starter
ctappan94
1983 CJ7
Yeah sorry guys. Probably 5.13s or 4.88s.. i want 38s but i wanted the t19 because im not really one for a useless first gear being that the.jeep will be on the road half the.time.. the granny gear will only get you to what..8 mph? Lol. I need a set of useful gears ..and i need to meet highway speeds maybe once a month
post #7 of 24 Old 09-29-2011, 08:44 PM Thread Starter
ctappan94
1983 CJ7
But also thank you to everyone who replied. You guys all had great input
post #8 of 24 Old 09-29-2011, 11:20 PM
80cj
80cj's Avatar
1980 CJ5
Where do you find a Dana 70 front? The only ones I've seen are on the GM Kodiak and similar trucks.
80cj is offline
post #9 of 24 Old 09-30-2011, 05:54 AM Thread Starter
ctappan94
1983 CJ7
haha not sure yet! I'm heading to a few scrap yards today..they're hard to locate.
post #10 of 24 Old 09-30-2011, 09:23 AM
Cutlass327
1978 CJ5
That much power, that strong of axle, and you are not going to wheel it? I would think that you would want the granny low! Granted, it is a useless gear for normal driving, but final ratio is still 1:1, so just think of it as a 3 speed. That granny would make for a nice easy crawl speed in low range, and I have no problems DD mine with the T150. It even made the 10 hour trip to Chattanooga and back last month at 65MPH avg speed...
Rick
Cutlass327 is offline
post #11 of 24 Old 09-30-2011, 11:14 AM
petey156
1977 CJ5
I am running a 302 t-19 Dana 300 I have the Novak adapter and rear output shaft. I love that combo. I just bought a set of Dana 60's for it.
petey156 is offline
post #12 of 24 Old 09-30-2011, 02:49 PM Thread Starter
ctappan94
1983 CJ7
so the t19 doesnt have a higher top speed than the t18!?
post #13 of 24 Old 09-30-2011, 02:51 PM
CSP
Both of them have a 1:1 ratio in fourth gear.
Just about any three or four speed transmission has this ratio in its highest gear.
CSP is offline
post #14 of 24 Old 09-30-2011, 07:24 PM
Stumpbumper
T18 and T19 both have a 4-1 ratio unit.
The T19 had a 6-1 in Scouts 5-1 and 4-1 in Fords 80's trucks and Bronco's
The T18 4-1 was way more common than the 6-1.
The 435 is good unit also.
Read the Novak site for lots of info on these trany's.
The T19 is fully syncro! thats what makes it so usable!
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #15 of 24 Old 09-30-2011, 09:12 PM Thread Starter
ctappan94
1983 CJ7
Not to be an idiot...but whats a synchronized transmission mean
Dana 30 ->ford 9" or Dana 44 Front Axle Swap smoothop Jeep CJ Forum 9 09-18-2011 09:28 AM
ford 2wd t-19 to dana 300/20 petey156 Jeep CJ Forum 1 06-01-2011 07:52 AM
Ford Dana 60 rearend 77cj5BEAST Jeep CJ Forum 9 02-23-2007 02:19 PM
Ford T-18 to a Dana 30 ncdeerejeep Jeep CJ Forum 8 11-28-2006 07:22 PM
Best Axle out there??? (Ford 9"/ Dana 44/AMC 20/OTHER) jeepcj7 Jeep CJ Forum 4 03-21-2003 11:54 PM
