Ford swap, roll over valve, charcoal cannister question - JeepForum.com
post #1 of 6 Old 12-29-2013, 06:17 PM Thread Starter
yellowreg26
1982 CJ7
Hey Guys,
I'm new member to the forum but have used it for a while now to get a ton of information. My project is a 82 CJ7 with a fiberglass body. It's a project that the PO gave up on. So far i have the drive train is in as well as the carburated Ford 351W. The suspension is OME and this forum was my saving grace. It was a really easy swap after reading what everyone else discovered. I used the search function but cant seem to get an answer to this....
I'm about to start running all new fuel lines. With this swap, do I need to keep the roll over valve and charcoal canister? It may be a stupid question but I can't figure it out. Any assistance will be greatly appreciated. I have a million other questions but this is the next part I'm going to tackle. Thanks!!
yellowreg26 is offline
post #2 of 6 Old 12-29-2013, 06:34 PM
Spieg8
1984 CJ8
I would. You can use the Ford canister if you prefer.
Spieg8 is offline
post #3 of 6 Old 12-30-2013, 08:19 AM
CSP
x2, keep it in place. The need to vent the tank has nothing to do with the engine.
CSP is offline
post #4 of 6 Old 12-30-2013, 12:05 PM Thread Starter
yellowreg26
1982 CJ7
thanks for the replies. So if I'm understanding this right, I should just run the vent line up to the canister and plug the other ports on the canister?
post #5 of 6 Old 12-30-2013, 12:41 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
No, you'll still need a purge signal line and purge line for the canister to function properly.
If you're running a carb, you may want to connect the bowl vent, as well.
Good luck,
Matt
Matt1981CJ7 is offline
post #6 of 6 Old 12-30-2013, 12:48 PM Thread Starter
yellowreg26
1982 CJ7
Thanks Matt! That's exactly what I needed. I appreciate the reply.
