Ford shock towers on 73' CJ5 - Page 2 - JeepForum.com
post #16 of 20 Old 01-31-2014, 12:33 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
easy to C/P from PB when on the big computer,but from the ipad mini, not as easy...
older pic showing front tower placement. used some U shaped weld-on shock mounting tabs and placed that directly on top of axle tube. Current tires 37" MTRs. (wish i could find more of the 'old' style MTRs, argh...)
another--- seems so many modifications ago, but you can see the stance of front shock.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #17 of 20 Old 01-31-2014, 12:44 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
found some more
hey, watcht hat hammer swing! LOL
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #18 of 20 Old 01-31-2014, 01:01 PM Thread Starter
Stumpfarming
1974 CJ5
I see that you gusseted the sides of the tower to the frame on the front. The front mounts are also canted out quite a bit, while your rear towers are mounted more vertically. I'm thinking that with the narrower axles I have, I will likely need to mount my front towers at an angle similar to how you have the rear set up, and I will need to set both front and rear with substantially less out boarding. I'm thinking about trying to use the stock lower mounts, unless this pulls the shock in too close to the frame that it rubs at full extension. Thoughts anyone?
Thanks for the photos. They are always helpful!
Stumpfarming is offline
post #19 of 20 Old 01-31-2014, 01:03 PM
cw05
Here are some "lightly used" ones:
http://www.trailworthyfab.com/Goodye...ake-Off-s.html
cw05 is offline
post #20 of 20 Old 01-31-2014, 01:12 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
16.5 is a no no, thats why they're so cheap. I need17"
and yes, we gusseted the front towers. Lots of stress and leverage on flimsy CJ frame. The to-do list includes an engine cross support to tie both towers together under hood.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
shock mount
