Ford 9 Inch Build Questions - JeepForum.com
post #1 of 4 Old 04-11-2008, 04:23 PM Thread Starter
bdmonist
WTF is that?
bdmonist's Avatar
Just picked up a 9 inch bare housing and am starting to plan out the build. I know very little about these axles at this point. I have searched on here and on Pirate as well as Google and found some pretty good info. However, I am at the point where I still have some questions about what questions to ask
90% chance I am going SOA and will have 36" tires.
It is currently 60.5 inches flange to flange on the bare housing, I think that would probably put me around 65 or 66" or so WMS to WMS. Is this correct?
I will be cutting the axle down, targeting about 58.5" WMS to WMS. When I do this, how do I determine where to have the custom axles cut and resplined. What is the measuring point?
I found some threads on pirate showing how to junkyard disc brakes. Anyone done this?
It has the large bearing housing - I want to go with 31 spline axles i think. ummm do I?
Does anyone have a junkyard rebuild thread or any other info on what they have done?
I know this all pretty general, but any help, advice is much appreciated. Thanks.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #2 of 4 Old 04-11-2008, 05:05 PM
Bard
I will get back to you on this. I passed on a dana 44 front and ford 9" rear, but my buddy bought them. They are still out and finally visibile from the snow, but I can measure them and send pics, it has disc brakes set up and I can get the info. it also has superior axles in it.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 4 Old 04-13-2008, 06:07 PM Thread Starter
bdmonist
WTF is that?
bdmonist's Avatar
To the top for the weekday crew!
bdmonist is offline
post #4 of 4 Old 04-13-2008, 07:03 PM
high51977
It is currently 60.5 inches flange to flange on the bare housing, I think that would probably put me around 65 or 66" or so WMS to WMS. Is this correct?roughly yes
I will be cutting the axle down, targeting about 58.5" WMS to WMS. When I do this, how do I determine where to have the custom axles cut and resplined. What is the measuring point? not sure on this one
It has the large bearing housing - I want to go with 31 spline axles i think. ummm do I? YES ABSOLUTLY
Does anyone have a junkyard rebuild thread or any other info on what they have done? 70's ford f150 truck will have the center section you need and alot of them have limited slip factory
I gave you some answers in bold in the quote I reccomend Moser axles for the 9" and their tech support is great They may even tell you where you need to take your measurements Currie enterprises is another company that could give you info on the shortening of your 9"
Play by the rules you're gonna miss all the fun
high51977 is offline
Early bronco 9 inch ford swap dr_hunt Jeep CJ Forum 0 09-08-2009 09:11 AM
Ford 9 inch robertmspeakout Jeep CJ Forum 13 10-12-2008 09:16 AM
Ford 9 inch SavSilvrCJ Jeep CJ Forum 2 11-19-2007 06:20 PM
Ford 9 inch Question(s) 79CJ54wheeler Jeep CJ Forum 4 02-11-2007 04:57 PM
Ford 9 inch Rear axle jeepthing360 Jeep CJ Forum 4 10-12-2006 08:28 PM
